Question about HP Compaq MV 5500 15" CRT Monitor
Out of frequency range need to set resolution lower?
judesoul
  • 127 Answers
SOURCE: out of frequency range set lower resolution
reboot the system by pressing F8 if your using windows OS and select last good configuration.
you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
hope this helps, please rate.
Posted on Feb 06, 2009
  • 205 Answers
SOURCE: moniter says out of frequency set resolution lower or see user guide
The settings you need to change are actually on the computer's video hardware. Assuming you are using a Windows machine, right click anywhere on the desktop. Select Properties, then the Settings tab. You should see a resolution slider that you can adjust. There should be an Advanced button that will give you access to other settings that are possible with your hardware. This is where you can adjust the frequency.
If you are unable to see anything because of this problem then you may need to boot into Safe Mode to correct this. Let me know.
Good luck.
Posted on Dec 22, 2007
SOURCE: Resolution Problem
Salut je vous ai écrit hier au sujet du moniteur acec qui j'ai un problême j'ai vue que vous m'avez envoyé un courriel mais je ne l'ai ^pas reçu alors j'aimerais bien savoir le résultat du problême.Merci j'atte Comment by Guest, posted on Mar 06, 2008 Mon écran Nec 1560+ jndique ceci impout ranger j'aimerais savoir comment lui redonner c'est paramètre de nouveau car quand j'ouvre mon ordi la page de Windows ouvre mais ensuite plus rien à l'écran même pas ma souris elle reste noir alors j'aurais besoin d'une solution rapide concernant mon écran"Merci et J'attends de vos nouvelles,(andreassir@hotmail.com )nds de vos réponses
Posted on Mar 06, 2008
kingpin27
  • 13 Answers
SOURCE: out of frequency range set low resolution or refer monitor manual
TO RESET IT START YOUR COMPUTER IN SAFE MODE AND GO TO DISPLY SEETTINGS SET YOUR MONITOR AT VERY LOW 32BIT 800 BY 600 PIXELS IT WILL SOLVE THE PROBLEM THAN RESTART THE COMPUTER
  • 3940 Answers
SOURCE: out of frequency set resolution or see monitor
If you are getting a splash screen (COMPAQ) then video goes black, you can try this. Boot system in Enable VGA mode from the F8 menu and see if you get to the desktop. If you do, you can then go to display properties and adjust the resolution to the Optimal for the monitor.
If you do not get a splash screen, check you cable connections and ensure the Video cable is properly seated and no bent pins. If issue is occurring after the system was moved, also ensure that the correct video adapter connection is being used on the tower, as there may be 2
Posted on Oct 04, 2009
My hp monitor S5500 when boot on it desplay out of frequency range and set resolution lower or see monitor users guide. What can i do to clear this information.
It means that the resolution set in the pc is higher than what your monitor can handle. Boot in Safe Mode, go to Control Panel > Display and in the Settings put a lower resolution - 800x600.
Jul 15, 2011 | HP Computers & Internet
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
ViewSonic VE155b
this means that your computer is set to either a too high frequency or too high resolution. Try to lower the resolution setting of your desktop step by step, until the message disappears.
Jul 23, 2010 | ViewSonic VE175b 17" LCD Monitor
Frequency out of range
the monitors resolution range is only to 1280X740 or 780
and your video card may also need an upgrade.
The game may require a higher resolution that is not compatible with the the devices mentioned.
Jul 08, 2010 | E-Machines eMachines Monitor E15T4
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
  2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
  3. Scroll down to highlight Enable VGA Mode , and press ENTER .
  4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor.
May 20, 2010 | HP L1506 15" LCD Monitor
AOC 771S monitor always appear "not support out of range even if i already set my resolution to lowest.
the lowest resolution is not always supported. by the range maybe referring to the frequency. change that, that should work. if you are not sure, look at your monitors manual, it will tell you resolution as well as frequency optimal settings
Apr 20, 2009 | Computers & Internet
My LCD show me "Out of range" when it is loading the windows. I need the driver. Thanks.
You will nee to find out the frequency range of your flatscreen whick should be in the book that came with it. Also, try pressing f8 and see if u can see the menu that comes up, if u can see it then select safemode and see if it will boot like that. If so, install the correct driver for the flatscreen.
your drivers are at this link.
http://download.aopen.com.tw/userdownload_List.aspx?RecNo=10160&Model=1425
Feb 26, 2009 | AOpen F2705 17" LCD Monitor
Out of frequency range set lower resolution
Feb 06, 2009 | Compaq Computers & Internet
Out of range frequency
Lower the PC display resolution to a lower refresh rate.
Jan 09, 2009 | LG 42LC2D 42 in. LCD HDTV
DVI Digital out of range
It probably means the frequency is to high. Whether Windows, Macintosh, or Linux, you will need to lower your frequency. 60hz is the best for LCD, DLP, & Plasma. The resolution will be better set at 1024x768 as well.
Nov 12, 2007 | NEC HT1100 Multimedia Projector
HP Compaq MV 5500 15" CRT Monitor Logo
5,879 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
