Have a 96 version of redbarron, sierra on-line.... won't work in new pc, comes up with memory shortage error... no a drive to create boot disk operating system is windows xp
    Sergeant:
  • 223 Answers
I would copy all red barron files from the disks to the computer into a single folder. then right click on the launcher icon. (select properties) then look for compatability tab or options. Set this to windows95. Then double click it to launch the program. I dont understand your boot disk comment.
Posted on Aug 28, 2010
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
How to format a pc
You need to create a bootable CD that will delete all of the information on the hard drive permanently. Here's a source for that software: http://www.killdisk.com/downloadfree.htm It's simple: after you create the bootable disk according to the instructions at the link I provided, load it into your primary optical (CD/DVD) drive and then reboot your computer and when your PC goes through it's Boot sequence it will automatically boot from the CD you created and then you just follow the prompts. NOTE: before you run create the boot disk, you should check your boot sequence in BIOS and make sure that the the primary optical drive is first on the list or else the boot CD won't work.
Apr 29, 2011 | Video Game Consoles & Games
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
I am on Ms Windows XP Professional with Ms Word 2007. An error message says " there is not enough memory or disk space to run word". Expect a solution on line free of charge.
1. Resolution from Microsoft.
or
Most probably your users' profile is corrupt!!
Try this,
1. Created a new user profile
2. Use windows cleanup to delete old files.
3. Restart PC and use new account.
4. Works...?? when you open Winword?
5. Then use your newly created account.
** Don't forget to backup your necessary data first
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Microsoft Office Professional 2007 Full...
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Can not re-install XP. Get "Unmountable boot volume" error.
Usually it's because you're missing the SATA drivers.
Did you slipstream those in too?
Jun 15, 2009 | ASUS Eee PC 1000H Laptop
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
My Computer does not boot
This could be a host of different culprits.
First, if you have more that one memry Dimm in the computer, removed one the restart to see if it boots. If it doesn't boot swap it out with the other memory Dimm. This will eliminate the memory. If it's not the memory, then it may be your hard drive is bad.
If you can get onto a friend's computer, do a Google search for "The Ultimate Boot Disk"
When you find it ,it will give you instructions on how to make the boot cd. Once you create the disk, you can use it to test your system board,hard drive and memory.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Computers & Internet
PXE boot slow, creation of RAM disk failed
RAM disk requires actual memory in order to create a 'virtual' drive. My first instinct would be to check to ensure that RAM is actually available. Perhaps memory is faulty or configured improperly.
Sep 06, 2006 | Microsoft Virtual Server 2005 (w15-00001)
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
