Question about Freezers
Water is building up in the bottom of my side by side freezer and freezing.
I can't identify where the water is coming from, but it build up and freezes on the floor of the freezer if I dont remove the ice daily it leeks on to the floor in my kitchen. I have discolouration on a seem below the freezer compartment on the case.
    President:
  • Freezers Master
  • 2,651 Answers
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on May 08, 2008
Why is water in bottom of freezer
there are 3 problems I've come across with water leaks on this model. if there is ice build up on the back of the freeze it could be a drain problem or if its around the ice maker it could be that the supply tube is too long. also watch out if you push the unit too far back against the wall the gray water supply line could snap off ( replaced 6 of these)
Jul 31, 2014 | Whirlpool Freezers
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
Sep 16, 2009 | Woods Upright Freezer MU07W
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
215 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
