Question about Hotpoint FFU00 Side by Side Refrigerator
Ice dispenser flap won't close automatically
My ice dispenser flap dosen't close automatically (Hotpoint). It stays open after dispensing ice . If I "tap" it lightly, it closes. Any ideas?
    Genius:
  • 1,073 Answers
Replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
Posted on May 07, 2008
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
Ice door flap will not close
I had a similar problem once. i opened the door and used a hair dryer blowing into the dispensing area of the door. There was a ice build up that was not visible with a quick look. It takes a while so be patient when thawing and be sure not to use too high of setting so you dont deform any of the plastic parts.
Mar 17, 2014 | GE Profile PSS26NGS Side by Side...
Fixing in door ice dispenser
What is the model number of the unit?
Nov 23, 2012 | Kenmore Side by Side Refrigerator
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Flap for ice dispenser won't close
ok you have to replaced the flapper (door recess asm) here is the part no. WR17X3093 makle sure to defrost all ice or snow around the flapper and replace it with the new one
Aug 04, 2011 | Hotpoint HSS25GFP Side by Side...
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
Hotpoint ice dispenser door not sealing
clean with white vinegar to remove lime deposit.
flapper may have got bent, bend back or replace flapper.
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Hotpoint FFU00 Side by Side Refrigerator Logo
690 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
