Question about Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner works as long as outside temps are under 95 degrees then it trips the braker. can the outside fan not ajusted in the shroud right or low refrigerent cause this.
    President:
  • 1,515 Answers
Hi, most all a/c that are on the market are designed for that exact temperature, 95*F. After that they will loose up to 40 % of there efficiency. But tripping the breaker indicates it is working to hard and over ampping so there is a problem up top. It may just be a very dirty condenser coil which will cause this unit to build the high head pressure causing the compressor to draw more amps then normal and will trip this breaker. If you can, go up and remove the cover. Watch it run to see if the condenser fan motor is running good. Look at the coil for dust and dirt build up. Its a good sign that it cools at 95* F, so I believe its just a dirty condenser coil. This will cause your internal pressures to peg out in temperatures at 95 and above!.Even if it looks OK, kill the power and run a water hose up top. Was out this coil and watch the dirt run out of it. I have seen the head pressure on units at 400 P.S.I. with a dirty coil and after washing drop 200 P.S.I!! If the fan is running good, this will be your problem. Before you go up, take a good flat heat screw driver along and when you are done cleaning this check the electrical box, and make sure all of the main connections are good and tight. Check to see if there are any signs of burned wires as this will also trip breakers as when loose they will create heat and burn the ends. This will solve your problem. You may want to check the 2- wires at the breaker also, just be sure it is off and tighten just the wires that go into the breaker as they will be dead at that point. Please use caution!. Doing all of this will take care of your problem, I am sure unless you have a internal compressor problem which I don't believe you do. Please don't forget to rate me as I know you will be kind to me. Please keep me posted and I will be checking up on you also. I wish you the best.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Aug 28, 2010
Outside heat stops ac operation
clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Feb 06, 2014 | Dometic Rooftop RV Air Conditioner
Not cooling
outside freeze sensor locking out operation
Jan 04, 2014 | Dometic Rooftop RV Air Conditioner
ModelB3200
high discharge pressure can be caused by dirty coil, slow speed on condensor fan or operating on a day in excess of 95 degrees. that is what all a/c mfg. do designed for 95 degree ambient
Jun 23, 2013 | Dometic Rooftop RV Air Conditioner
What is the normal vent air temp on cooling on a Dometic B3341
Up to 20 degrees less than than the ambient outside temp.
Nov 24, 2010 | Dometic Rooftop RV Air Conditioner
I live in AZ. my RV rooftop AC works as long as outside temps are under 95 degrees then it trips the braker. can low refigerint or outside fan not in the shrowed cause this?
The fan not in the shroud may cause this. Are you sure the condenser fan is even running or running at the right speed? If its not running, the compressor head pressure will build up until it possibly pops the breaker.
Jul 28, 2010 | Dometic Rooftop RV Air Conditioner
Not enough cold air out of dometic roof air outside temp 74 degrees
Air filter? #1 cause of air conditioning and heat pump problems. Filters are cheaper than repairs, a lot cheaper.
Mar 27, 2010 | Dometic Rooftop RV Air Conditioner
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
109 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
