Question about Medical Specialties Aeroneb Go Micropump Nebulizer By Medical Industries
Aeroneb go no vapor output --hardly used - Medical Specialties Aeroneb Go Micropump Nebulizer By Medical Industries
My vicks 1.5 vaporizer doesnt put out steam after using 5 times, flaky brown/grey things are in water , why? cant it be fixed
Is it limed up?-- in other words, the Hardness (Lime and Calcium) in your tap water has clogged up the heating coil..) Possibly the little grey things floating in the water, could be the residue from the water, left behind in the process of evaporation.
If this is the case-- gently heating and flushing Vinegar water thru the heating section of the Vaporizer, might be necessary every few times,- if your water is that 'hard'!
Feb 24, 2015 | Vicks Humidifiers
What is an evaporative humidifier?
The evaporative system uses to draw water out of the reservoir. A fan blowing over the wick lets the air absorb moisture. The higher the relative humidity, the harder it is to evaporate water from the filter, which is why this type of humidifier is self-regulating, as humidity increases, the humidifier's water-vapor output naturally decreases.
Sep 05, 2012 | 1topstore Fish
What is a mercury vapor lamp?
Mercury vapor lamps have an output spectrum that is almost entirely blue-white. The spectra is not continuous, and just like fluorescent tube, there are spectral peaks at certain wavelengths.
Aug 21, 2012 | Fish
MY DUCANE FURNACE FIRE TOO HARD ON IGNITION
Gas pressure may be too high. you need to check the pressure at the regulator. 3.5in. wc for natural gas and 11.7in. wc for LP gas. sometimes when the system does not purge the gas vapors with the draft induce blower, when the ignition starts it will fire hard because of the excess gas vapor found in the burner chamber. hope this helps you out.
Nov 27, 2010 | Heating & Cooling
Unable to put gas in at at gas pump
SOUND LIKE EVAP SYSTEM FAILURE.CAUSING EXCESSIVE FUEL PRESSURE VAPORS BUILT UP IN FUEL TANK.TAKE IT TO DEALERSHIP THEY HAVE TO USE DIAGNOSTIC EQUIPMENT TO FIX.THIS IS A LITTLE TRICK TO GET GAS IN TANK BACK OUT SPOUT A LITTLE NOT MUCH TO LET VAPORS ESCAPE WHILE YOU PUMPING GAS.YOU NEED TO FIX.FUEL PRESSURE VAPORS WILL BUILD UP ENOUGH TO BLOW UP FUEL TANK ESPECIALLY ON HOT DAYS.
Mar 06, 2010 | 2001 Chevrolet Blazer
There are puddles on the floor, rear passenger side of my vw jetta (87). I have had the vapor seals replaced on both passenger side doors.
Check the sunroof drains. The vapor panels are hard to make stick. We used to use hot glue and duct tape to help hold on the vapor panals. Check the drains in the doors.
Feb 01, 2010 | 2000 Volkswagen Beetle
Vulcan freezer has condensate coming thru freezer wall and thru
no epoxy is not enough
you need to insulate the floor use sheet unsulation it comes in 4x8 and then sheet over it with ply wood like a 5/8 ply seal arround the edges with a good indoor our door silicone then use epoxy th seal the ply
by simply sealing the floor you will get loss and make your pump work 3-4 times as hard using 3-4 times the hydro witch means more money over the long haul
spend some time and cash now or spend a lot of cash later.
Jul 23, 2009 | Freezers
No water vapor coming out
You might need to check either the water level sensor or make sure that there aren't any deposits on the nebulizer. I just posted the following sections from the manual for another problem:
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly. (I scanned a page from the manual that shows how to dismantle and reassemble the sensor: here)
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 19, 2008 | Crane Pig Humidifier
Medical Specialties Aeroneb Go Micropump Nebulizer By Medical Industries Logo
Top Medical Specialties Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Medical Specialties Health and Beauty Expert? Answer questions, earn points and help others
