How do I network my xerox 432 DC printer,scanner, copier does the 432DC support emailing documents after they have been scanned?
    President:
  • 2,072 Answers
A DC version can't be networked. It has to be the ST model.
It can be converted though.
A 432dc is simply a digital copier with no print capabilities.
That has to be a 432 st.
Posted on May 07, 2008
How do I set up network scanning?
Hi Kenneth,
I saw your name on a previous query.
This best ting with this one is to follow any information on the www.Xerox.com website.
Good Luck.
May 22, 2015 | Xerox Phaser 3635MFP/X Multifunction...
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Scan to email
  1. Place the document that is going to be scanned face down on the scanner. Press the "Scan" button that can be located on the scanner. Another way to perform a scan is to click on "Start," then go to "All Programs." Move the mouse pointer up to "Accessories." Go down to "Scanner and Camera Wizard."
  2. Click on "Scanner and Camera Wizard." Click "Next." You will be asked to choose a preference. Choose a preference, then click on "Preview" to preview the document.
  3. Click on "Next" after previewing. Type a picture name and the destination where you want to save it. Click on "Next." The document will start to scan. Click "Finish" to complete the scan.
  4. Go to your email account. Click "Compose" to start a new email. Look for "Attach File" and click on the "Browse" button across from it. The "Choose File" window will open up.
  5. Go to the destination where you saved the scanned document. Choose the name of the scanned document. Click on it to open up the file, then click on "Open."
  6. Add the necessary information in the subject line and the body of the email. Click on "Send" to complete the process. The document will be sent as an attachment file.
Feb 05, 2011 | Xerox Phaser 3200MFP/N Laser Printer
We have hosted Exchange email and I've been tasked with getting a xerox 3635mfp to scan to email. So far no luck even though I believe I've input all the correct information.
for scanning with Xerox MFP it is convenient to use MFP TWAIN Importer (http://www.scanworkssoftware.com/twainimportermfp.aspx ) It allows scanning from Xerox MFP directly to user's workstation with secure way and without any additional efforts.
Nov 05, 2010 | Xerox Phaser 3635MFP/X Multifunction...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Scan failure
Anything with scanning problems on this machine, would require a service call.
Turning off and wait for at least 30 seconds and powering on the machine "Might" get the machine back to a good "Ready" condition.
The problem might be a bad scanner motor gear or even curciut board. There might even be some major binding that might knocked out some sensor, giving this condition.
Most times, a service call needs to be placed with Xerox.
Mar 13, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox M20i scan to e-mail
You can not scan with a M20i with an Ethernet cat 5 cable. It can ONLY be done via a USB or parallel cable.
If you don't believe me, which many on here wont accept the truth, here is the note from the Xerox documentation..
The WorkCentre can scan a document via Direct Scanning using a USB or Parallel Port connection only.
Jan 11, 2009 | Xerox WorkCentre M20i All-In-One Laser...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
432dc scanner
You can't with the DC version of the machine, It has to be an ST version. You have to add what is called an ESS module, and that is quite expensive.
YOu can buy a smaller multifunction machine for less than it would cost to upgrage a DC to a ST.
I am assuming you are asking how to scan to the network or P.C. and or Scan to E-mail.
Aug 26, 2008 | Office Equipment & Supplies
123 people viewed this question
jasbo
jasbo
