Question about GE A730 Digital Camera
Hi, My GE A730 continues to have the "Lens Error" even after I have repeatedly tried the your solutions. This is not necessarily an issue that I want to brink to a repair shop because the camera is only valued around $100. I would appreciate any additional help that you can offer. Thank you in advance, Todd
    Brigadier General:
  • 11,967 Answers
Todd....I don't know if you've tried my suggestions or those of someone else. In any case, here are mine: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 28, 2010
It is reading Lens Error how to fix
Hi there:
I suggest check in this link, some tips about fixing-lens-error-on-digital-camera.
Hope helps.
Aug 14, 2012 | GE A730 Digital Camera
My 7.0 megapixel G1 camera is reading lens error how to fix problem
Hi there:
This link can find details about everything you can try to fix it without sending it to a repair shop: Fixing-lens-error-on-digital-camera
Hope helps (remember to rate and comment this answer).
Hello,my problem is about lens error of my ge camera?whay should i do?where can i visit a nearest service center in my place which is Cebu.thanks.
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its happens. There is a chances of lens guide pin disturbed or damaged & thats why continues failure. Its mean he inform you there is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks
Dec 19, 2010 | GE A730 Digital Camera
My camera says lens error and shuts down
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Jul 17, 2010 | GE A730 Digital Camera
I keep getting A lens error
Dec 23, 2009 | GE A730 Digital Camera
Lens error keeps coming up and the lens won't go in...it is a GE A730.....can anyone tell me how to fix this......
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | GE A730 Digital Camera
GE A730 LENS ERROR
Hi sadloserx:
I am inserting this from a previous post, since this seems to be the same problem.
Also lens problems have to be described in full to see what is wrong. The following will give you some idea as to what I am saying.
This camera is telling you that there is a problem with the lens, either in the tracking, mechanical, or electrical circuit.
Try this: If the lens extends at all... then pull on the lens or push in to try to reset the tracking of the lens.
If the lens does not extend at all and makes noise, then it has problems in the lens gearing or motor.
If the lens makes no noise at all and you get the error with the shut down, then more than likely there is nothing that can be done.
Try this at your own risk:
With the camera off, gently hit the camera on a padded (folded towel) cloth on a solid surface, using one of the corners. This may jar the internal parts enough to make the camera work again.
BY doing this, you do risk damaging the camera beyond repair, however, if you have a camera not working anyway, it may be worth it.
I have fixed two cameras in the past this way. However, nothing is guaranteed.
Finally:
Find a repair shop and have it fixed. (These kinds of repairs can cost $150.00 or more). That will depend on your value and the age as well of the camera.
Sell it as is or for parts on a site such as Ebay.
Sep 25, 2008 | GE A730 Digital Camera
Lens error
you need to send this to a repair shop, for immediate cleaning, sand can practically stucked in betweeen mechanical parts and cause binding
Jul 25, 2008 | GE A730 Digital Camera
My ge a730 digital camera
Try this...Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Jun 18, 2008 | GE A730 Digital Camera
General Imaging
Call 800 730 6597 to have it replaced.
Trevor Gordon
Senior Customer Tech
General Imaging Company
(Exclusive GE Digital Camera Licensee)
Jun 01, 2008 | GE A730 Digital Camera
GE A730 Digital Camera Logo
48 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
jjanesic
jjanesic
Level 1 Expert
Are you a GE Camera Expert? Answer questions, earn points and help others
