Question about Singer 5050 Mechanical Sewing Machine
Feed doesn't feed Singer 560
The feed doesn't advance the material. It will go back and forth for forward or reverse stitching, but doesn't go up and down.
There should be a control to raise or lower the feed dogs, lower to stipple and high to sew normal. it sounds like you may have lowered them
Posted on May 07, 2008
My harmonies 400 singer machine will not feed the material through to sew
Check that the stitch length is set higher to advance the fabric. Verify the feed dogs have not been dropped for darning.
Aug 28, 2017 | Singer Sewing Machines
Hi. I have a Singer 132k6. The feed dog goes up and down, but not back and forwards. Any suggestions?
Check that the stitch length is set high enough to actually advance the fabric. Otherwise, the feed dogs may be seized or defective.
Feb 14, 2017 | Singer Sewing Machines
Singer model no 9022 feeder feet does not move material thread bunges under material
Check that the stitch length is set high enough that the feed dogs will actually advance the fabric. Setting the stitch length too low will cause the machine to basically sew in place.
Also, check that the feed dogs have not been "dropped" to allow darning or free motion quilting. Dropping the feed dogs lowers them so they will not rise above the needleplate and will not grip nor move the fabric.
If your machine is mechanical (not computerized), it may need a good cleaning and oiling. If the old oil has solidified, it could be preventing the feed dogs from moving like they should.
Aug 27, 2016 | Singer Sewing Machines
Raise and lower the feed dogs
the feed dogs are the saw toothed piece under the press foot
they go down move forward raise up move back in time with the needle to pull the material through for the next stitch
the amount of movement ( stitch length) is set by the position of the forward and reverse lever/ knob
Dec 10, 2015 | Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Fabric not feeding on singer model 750
check that the feed button or lever is in the correct position
If it is in the centre position then the feeding foot doesn't know to go forward (normal ) or reverse
If electronic controlled the maybe a service is called for.
Mar 29, 2015 | Singer Sewing Machines
Singer 9015
check feed dogs are clean with no build up of lint and have sharp points on teeth
Feb 19, 2014 | Singer Sewing Machines
Singer sewing machine 1030 feed dog will not pull material in
try using maximum stitch length, if still not working try removing needle plate and clean you teeth
Feb 18, 2014 | Sewing Machines
The feed dog will not advance the material
Call Singer at 1-800-4singer and they will help you. I think a piece of the needle may be stuck in your feed dog
Oct 11, 2009 | Singer 3116 Simple
My kenmore 385 won't feed fabric
Check to see what pattern is selected. Be sure it isn't the buttonhole.Select straight stitch.Move the stitch length setting to 4.Turn the handwheel and see if the feed dogs move forward. Press the reverse lever and see if they move backwards. Select straight stretch stitch and turn the wheel to see if the feed dogs move forward and backward.Check the presser foot release on top of the machine and make sure there is pressure on the foot.
Sometimes the reverse assembly on this machine stops working because it has the wrong type of grease on it and it turns into a hard gummy mess that won't let it work.
sewman7
May 14, 2009 | Sewing Machines
Singer 5050 Mechanical Sewing Machine Logo
228 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
