Question about Norelco Quadra 6885 XL Electric Shaver
How do I change the batteries in my 6885XL razor
  • Norelco Master
  • 1,602 Answers
You will find the correct battery pack for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Remove the two screws on the back to take off the back cover. One of the screws is hidden by the trimmer so you must extend the trimmer to see it. Once back is removed, remove the metal clip at the bottom end of the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Soldering is required to replace the battery pack. If you are not capable of soldering in the new batteries, you may want to consider buying the item below instead for easy installation
http://shaveroutlet.com/philips-norelco-7886xl-quadra-shaver-lower-unit-part.html
Posted on Aug 29, 2010
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
Tip
How To Change Replace Battery on a Electric Razor Scooter E200
<utube src="iR-CZ_uOvOo"></utube>This Video will show you how to replace or change the battery on your Razor E200 electric scooter.
on Aug 04, 2013 | Razor E300 Scooter
Arcitec razor 1050X will not cut whiskers reagardless of length, weather I shave every day or wait a few days. I must resort to using a twenty year old Norelco with old heads that still shaves much better...
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
Oct 12, 2010 | Norelco Arcitec Electric Shaver -...
Dead batteries
Hello. Since you did not specify which razor you have I am enclosing a blog which describes the process for most all norelco razors. Regards, Joe
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Dec 26, 2009 | Health & Beauty
I have a Norelco 6885XL electric razor that won't hold a charge. It will "recharge" to 44 minutes, but once below 39 minutes left it goes to 0 when turned on.
It's easy - I replaced mine (Norelco 6885XL) with a soldering iron & batteries I found online. Here's one place that sells them:
http://www.electricshaverstore.com/get_list_145.htm
As these are NiCd, I always drain them totally dead, then recharge, as this type of battery does suffer from the "memory effect".
Dave
Dec 16, 2008 | Norelco 7886XL Electric Shaver
Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
Mar 23, 2008 | Norelco Reflex Shaver 5885XL Electric...
Norelco Quadra 6885 XL Electric Shaver Logo
134 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
