Question about Konica Minolta Di1610 Copier
Code 14a3 how do i correct it - Konica Minolta Di1610 Copier
  • 60 Answers
The error code 14a3 notify the technician that CCD unit has failed . But you need a technician to do that.
Posted on Feb 22, 2011
Service call 14A3 in km 1690 mf
You can download the manual from this link but it sounds like a fuser problem. Not cheap !
May 29, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Service call 14A3 in km 1690mf
The bright light that reads the image of the original document is bad replace it. comes as the scanner
try this site for start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
14a3
The very bright light under the glass is not bright enough, have tech come to review it might need a new exposure lamp assy.
Feb 04, 2014 | Konica Minolta Office Equipment & Supplies
Error code 14a3
The CCD unit has failed.
Sep 07, 2010 | Konica Minolta Di1610 Copier
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
C14a3 error code konica minolta bizhub 161f
Hi jdt_mk,
Sorry to hear you have a C-14a3 code.
In my experience, this code spells disaster for the 161f.
The image reader has failed. The part can be replaced, but the cost would almost outweigh the cost of replacing the machine.
I have personally had to deal with two 161f with the same code.
Both times we changed the machine (because it was on contract).
Sorry it's not good news
Jan 13, 2010 | Konica Minolta bizhub 161f All-In-One...
My car radio security code will not unlock radio
Are you sure that you have
1...The correct code?
2...The correct Code Entry Instructions
If you require a code the radio will have to be removed from the car dashboard .
Then please POST A NEW QUESTION quoting  the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
If your radio is a RENAULT/PHILIPS then here are the correct Code Entry Instructions
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Sep 14, 2009 | Car Audio & Video
I have di1610 wont at all error ligth are flashing
Description
Machine may cycle ON/OFF repeatedly (keeps rebooting), will not power ON (no boot-up), no message on the operation panel, LCD displays extraneous
characters and/or error code C14A3 (C-14A3).
Solution
CAUSE: The PCL board draws too much current, causing PWB-P to fail. There is no problem with GDI versions of the machine; only machines with PCL
boards are affected.
SOLUTION: The PCL board has been modified to limit current draw. If the symptoms described above occur, replace both the PCL and PWB-P boards.
Note : The new-style PCL board can be identified by a yellow sticker. Machines that had the new-style board installed during production have a yellow
sticker near the serial number plate.
may want a service technician to check the PCL boards as above
Aug 04, 2009 | Minolta Office Equipment & Supplies
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Di1610 Copier Logo
366 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
