Question about Intel D865PERLL Motherboard
Intel D865PERLL Motherboard will not power up
System will not even turn on the power supply when the “Power On” Switch is pushed. Power supply & CPU fans & case fans stay off. Had a bad lightning storm. System was off but plugged into a UPS. UPS still works with other PCs. No obvious burn marks on the system or power supply . 5V power LED standby power was still working. Power On Switch was checked & OK. New power supply installed but system does not power up (no fans running).
I don’t have detailed schematics.
  • 2 more comments
  • nkda2000 May 08, 2008
    5/8/08
    Good morning Mike,
    Thanks for trying. FYI, I was deliberate in typing Intel D865PERLL. There are apparently several versions of the Intel D865PERL motherboards. The "LL" version has the LAN and Firewire built in. That is the version I have.
    FYI: Here is the Intel link to the details of the differences in the Intel D865PERL motherboards.
    http://www.intel.com/support/motherboard...
    I already have the pdf file whose link you sent. Unfortunately, it does not give a detailed enough schematic indicating which IC controls the power on for the power supply and motherboard. I was hoping there might be a small (16 pin DIP) that could easily be swapped to get the board running again.
    Do you have any additional ideas of where to look?
    Thanks for your help, Jim
    Mike,
    Do you have another Intel Motherboard ATC form factor which still supports Socket 478, with USB, LAN & Firewire builtin, AGP & 5 PCI Slots, that might still be available?
    Regards, Jim
  • Doctor PC
    Doctor PC Dec 21, 2011
    Sometimes when lighting strike the MOBO get fried.
  • Doctor PC
    Also Intel doesnt build MOBOs only chipsets.
    New Friend:
Since the board won't power up, try a jumpwire solution to start it through the ATX power supply connector. Green wire on ATX power supply connector to ground. You may have a fried connection to the power on line, and it can be anything from a blown resistor to a fried copper trace within the motherboard (which is multilayered)
Posted on Nov 24, 2012
    President:
  • 2,351 Answers
Hi nkda2000, this is as close as I could find for power schematics. Intel D865PERL
http://support.intel.com/support/motherboards/desktop/D865PERL/sb/CS-027143.htm
(There is no Intel D865PERLL board). Sure it's a typo. Have done searches for D865PERLL & found it (Not on Intle's web site) but when looking at the specs it's listed as D865PERL. (One L ) not two.
I hope the Technical Product Specification pdf can help you check the power on the motherboard.
Luck!
Mike
Posted on May 08, 2008
Switch from amd to intel motherboard now have no power
No. Power-supplies are compatible with both Intel and non-Intel motherboards. Look near the Intel CPU for a 4-pin "power" connector -- if there is one, connect the cable from the power-supply into that socket.
Jan 12, 2014 | BFG Technologies Computers & Internet
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
The computer wont start up, i can see a green light on the motherboard and nothing else. even the power button wont show up led light.
This can be a power supply problem or a motherboard problem.
One or the other has probably gone bad and must be replaced, if this is what happened.
Start by disconnecting all things from the motherboard except the CPU and memory.
If the system starts, then you've ruled out the power supply, CPU, motherboard, and memory.
If not, remove the memory and see if it tries to start. If so, then the problem is the memory.
If not, then it's definitely the power supply, CPU, or motherboard.
Aug 03, 2011 | Intel DH55TC Motherboard
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
Gateway 550GR Still Not Booting Up
Have you tried a different power-supply?
A power-supply must emit a few different voltages; if it fails to output one of those voltages, the fans still may spin, and the CD-drive-tray may still open, but the motherboard may not be getting the correct voltages.
Disconnect the AC power, and then open the case. Look at the capacitors (those black/silver cylinders with an X in their silver-coloured top).
Any capacitor that is bulging, i.e., does NOT have a perfectly-flat top, is leaking. Any capacitor that seems to have rusty-brown "sand" on top also is leaking. Either way, it's time to replace the motherboard.
Jul 03, 2010 | Gateway 550GR PC Desktop
Switch power error
bridge the power led on board, if it comes up, then your power switch is bad.
Mar 20, 2010 | Intel D865PERLL Motherboard
Asus p4p800s-x won't boot and no display on the monitor..
get a better power supply, as i understand it, youre computer is getting too little power from it. pick a power supply with more volt
May 28, 2009 | Intel ASUS P4P800S-X 848P Socket 478 DDR...
CPU fan switching on and off repeatedly, computer not switchingon
Check the power supply switch of your cpu casing, make sure that it will not stuck when you switch on the power.
May 08, 2009 | Intel Motherboard
Motherboard not working correctly.
The way that I solved the problem was to unhook each and every connection to the motherboard except for the 4-pin and 24-pin power supply connections, the processor, the cpu fan and the power on switch connectors, once I have done that, then I plugged in the power supply and turned it on, in which that worked! After that, I would hook everything up to the motherboard one piece at a time, in which after each piece I would turn the power supply on again to see if that was the problem. Starting with the hard drive, the memory sticks and then the DVD drive, and found out that was the problem. The cable between the DVD drive and motherboard was the wrong cable for that motherboard. I will purchase a new cable and see if that works!
Apr 21, 2008 | EliteGroup 945G-M3 (V1.0b) (945GM310B)...
Intel D865PERLL Motherboard Logo
648 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
