Question about Craftsman Garden
How to change the pull cord on a 32.. weed wacker
    President:
  • Craftsman Master
  • 1,545 Answers
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck!
Posted on Aug 29, 2010
My weedwacker was working fine. All the sudden it shut down. The rip cord won't pull out to start it up again. Need answer asap. Thanks
Jamie, could be a recoil problem, broken clutch, probable the engine has seized on your weed wacker. You can try and free up, rebuild or replace trimmer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What Stops Pull Cord for Gas Weeder
How to unsieze 2 cycle Weedeater
Seized piston engines can run again but not for long What do you think
Fixing seized up echo weed eater
Aug 15, 2016 | Garden
How do i fix the pull cord?
Take the starter cover off the side and look for the tangle in the pull rope.
Sep 07, 2014 | Garden
Help my weed wacker string
Pull the spark plug out and try pulling it over if still won't move might have seized the motor possible not enough oil in gas You can try if not to much damage done pour some kerosene or stove oil down spark plug hole let sit over night try again
Jun 08, 2013 | Garden
How do i replace pull cord on craftsman weed wacker model 316.791080?
is the pull cord in the front of the motor if it is it is not worth fixing it will take about two hrs to fix the motor will have to be pulled..
Jul 18, 2011 | Garden
I operate a 32cc Weed Wacker from Craftsman. It was working just fine, but all of a sudden stopped running and somehow I cannot pull the start cord, it got stuck. Where should I look first before opening...
The first thing I would do is remove the housing for the pull cord and spring to find out why it isn't pulling. That may be the same reason as to why it stopped and appeared to lock up.
Jun 19, 2011 | Craftsman Garden
I have a very deep yard. Approx. 150 feet from my nearest power outlet. Can I use your weed trimmer products? What is the recommended wire gage of the power cord I should use.
A 16 Ga extension cord will run 10 amps up to oo feet. Electric weed wackers run between 2 and 4 amps, so you should be fine with a 16 Ga cord.
Apr 29, 2011 | Garden
Hve a Craftsman Weed Wacker 24 cc Need to find out how to put new nilon cord in the weed wacker its been some time since i've done this.
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Jul 08, 2009 | Craftsman Garden
Replace pull cord on ryobi model cs30 weed wacker
Good fix, mrfixit-jerr! Also, if you remove the rear cover (4 screws) you can stabilize the crankshaft by inserting a screwdriver between the lobe of the shaft and the counterweight.
Apr 03, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
126 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
