Question about Vacuums
I have a Liftmaster garage door opener and the garage door faces south. Normally the opener works great except at certain times on a sunny day.The sunlight is not directly hitting one of the sensors but the door will comedown as far as half way and then it will go back up and the lights will flash. If I go inside and use the button I can hold it down until the door is fully closed. However, sure is a pain to have to take the car out, go back into the garage, shut the door and then leave the house via another door. Any idea on either what the problem is or how to fix it?
  • 377 Answers
Sounds like a problem with a limit switch or something getting in the way of the electric eye that interrupts for safety reasons. Clean the electric eye transmitter and sensor of debris and cobwebs and make sure the wires are attached properly. Check the operation of the lifting media track or chain. Has it been lubricated recently? If possible, clean the switch in the transmitter in the car, it may be shorting out.
Posted on Aug 29, 2010
Chain came off tracks...repaired it and now it will not run full cycle...only goes a foot or so and then stops
if your talking about a garage door opener , pull the manual release , drop the door all the way,, with the handle still disengaged,, push the button to drop the door,, latch the handle,, try that , if that doesn't work, you need to adjust the chain so that reaches the stops at the correct time, here is a video on it,, Good Luck http://www.ehow.com/video_8739813_adjust-chain-garage-door-opener.html
Sep 11, 2011 | Vacuums
My daughter's garage door opener (Chamgerlain 1/2 hp screw drive)makes a loud snapping noise when it starts to open (closing works OK), door shakes then opens rest of the way properly. Noise is loud...
what you have is,, the part that connects the door to the shaft is beginning to strip, this is pretty common in the screw type doors , its the part with the door release lever on it, you can find these at any home depot or Lowes
Aug 18, 2011 | Vacuums
Unable to open garage door with new craftsman system
Somehow this Garage Door opener problem ended up in with Vacuums!
Try again-- and make sure it gets in with Garage door openers!
Jul 03, 2011 | Vacuums
After a brief power outage my Marantec 4700 garage door opener has problems opening/closing. When opening it stops at the fully open position and the lights blink, when closing it automatically reverses...
This is not a sensor issue, I have a similar problem, sensors work fine, garage door is still fully functional, all operations, including safety sensors work properly, just the overhead lights flash. I suspect there was damage to the power board due to a power surge, going to order a replacement to see if it works, will let you know how it goes.
May 14, 2011 | Vacuums
I have a Chamberlain Liftmaster Professional 1/3 hp garage door opener. I'm unable to find the model number, but it was made in April 2004 and has an orange learn button. It has been working fine since...
Do you mean the numeric keypad is no longer controlling the garage door? If so, have you changed the battery for the keypad? Frequently, if the battery is low, the keypad will stop working when the door is closed but works to close an open door. On most Chamberlain garage door openers, this is a 9V battery. You may need a small Philips screw driver to open the battery compartment at the bottom of the keypad.
After changing the battery, try the learn code procedure again. I've found it easiest to have two people involved when programming the keypad to the garage door opener. One handles the Learn button and the other types in the desired code.
I hope this helps.
May 22, 2017 | Vacuums
I have a raynor flight star garage opener. Had a lighting strike 4 days ago. All power is good. The opener even has a little green light on the switch that is attached to it. However the opener is not...
You could always try unplugging the unit and plugging it back in. If that doesn't work the logic board is probably fried and unfortunately there is no replacement available for it any longer. You would need to buy a new opener. I'd recommend Liftmaster.
Jun 10, 2010 | Vacuums
Hi - my machine works perfect except that it has
I posted this same solution for another inquiry but I will state it again in case you can't find it. I tried everything as well to try and get my machine (only used twice) to **** up the dirty water and I couldnt' fix the problem - there was no suction at all. Then I discovered there is a tiny (about 1 inch square) red plastic filter that is in the removable section that has the round dial to switch from floor to tool. As I said, it is a small red plastic square and there is a little door on it. If you flip it open (It actually looks like it can be removed) you will probably find a bunch of hair or carpet fluff. Mine was completely blocked. Remove the stuff and your machine should now **** up the water perfectly. I hope this helps - it took me a long time to figure this thing out!
Sep 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
