Question about Samsung SyncMaster T240HD 24" TFT LCD Monitor
How to mount samsung t26hd or remove the existing stand?
SAMSUNG T26HD by bsblevy - 10/10/11 11:02 AM HI I HAVE A LCD MODEL SAMSUNG T26HD HE DOESN'T TURN ON, I TRY TO TURN ON WITH THE CONTROL REMOTE ,THE LIGH LED FLASH 4 TIMES AND AFTER I LISTEN A BEEPPPP...BUT THE TV STILL OFF, BLACK SCREEM, IF YOU CAN HELP ME WITH YOUR ANSWER I WILL BE GRATEFULL, THANKS
Posted on Oct 20, 2011
Where can I buy a new base for the Samsung 24
The original Samsung stands will be very hard to find, only available from somebody that has wall mounted their monitor and no longer needs the stand. You can get a third party stand such as the one in the link below that will mount your monitor. All modern monitors have mounting holes in the back for VESA mounting, this is a standard configuration.
http://www.amazon.com/Adjustable-Tilting-Mount-Bracket-10~25inch/dp/B003L171KW/ref=sr_1_12?ie=UTF8&qid=1339684562&sr=8-12&keywords=monitor+stand
Jun 13, 2012 | Samsung 24" LCD Monitor 2494SW
How to remove stand from television?
Lay your tv on its back and then look under the stand part and you will see the bolts or screws holding the stand in place.
May 30, 2012 | Samsung Televison & Video
How do i remove stand from samsung syncmaster 2333 to mount on wall
its a snap-type plug-in stand, just hold the stand firmly and pull the monitor equally upward, then it will snap quickly....... but a proffessional reminder! Before mounting your SyncMaster on a wall, be sure to plug the two (2) stand holes located at the buttom of the monitor. My Samsung SyncMaster 2333HD LCD TV was twice intruded by adult-size lizard, both incident resulted to main power board damaged!!!!
Feb 13, 2011 | Samsung SyncMaster 2333HD 23 in. LCD TV
Samsung LN37b650 television stand removal. how do you remove the stand on the set to mount on wall
Mounting on the wall, be sure use the short screws and no power tools. Hopefully it can help you and get a good commend.4933675.gif
Jun 10, 2010 | Samsung Televison & Video
How to remove the stand from samsung 860 52"
  1. Spread the comforter out on a flat surface such as the floor.
  2. Step 2 Lay the Samsung flat-screen television face down on the comforter on the floor.
  3. Step 3 Use the magnetized screwdriver to gently unscrew the four to six screws securing the stand to the television.
  4. Step 4 Remove the screws with the magnetized screwdriver. If you do not have a magnetized screwdriver, cover the end of a normal screwdriver with masking tape with the adhesive side out so that it will catch the screw and pull it from the hole.
  5. Step 5 Pull the stand from the back of the television
  6. Step 6 Mount the television to the wall with wall-mounting hardware you can purchase from any home entertainment store.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 15, 2009 | Samsung LE40R74BDX 40 in. LCD Television
How to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
Sep 01, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Sep 15, 2007 | Samsung SyncMaster 970P 19" LCD Monitor
Samsung SyncMaster T240HD 24" TFT LCD Monitor Logo
408 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
