Question about Xerox Phaser 8500/DN Printer
XEROX 8550 7,010.43 error code
The print warms until 40% and then shows the message. I have read somewhere that is a something with printhead position.
I have checked 1.Printhead
2.Whiper Drives , and clutch.
Ameally out of ideas what migth be.
  • Anonymous Jan 08, 2009
    xerox phaser 8860 error 07,010.43:46682
    Printer warms up part way and gives this error message. I'm not to sure about how to take printer apart and repair guy can't get here till monday. can anyone provide detailed instruction as to how i may fix this????
    President:
  • 2,072 Answers
There is a print block located on the left side of the machine looking from the front. It is near the bottom of the machine, Staineless steel, about 1 inch square.
It normally has ink in it and causes the print head to pivot slow.
You have to pull the spring holder up and to the left, remove that block and clean it well. That should resolve your problem.
You want to remove as much excess around the block as you can.
Posted on May 07, 2008
  • 10 more comments
  • Rick Kasper May 07, 2008
    It is about mid way back, near the bottom of the machine,
    It is the only stainless steel item you will see there.
    I would am almost 99 percent certain you will find it is contaminated with some of the ink.
  • Rick Kasper May 09, 2008
    Are you still getting that code???
    If so there is one odder thing that can be causing it. It's really hard to explaine. If you provide an E-mail address I will see if I can copy and past the photo of it as it is easier to explaine with the graphic.
    I am surprised, that print block is the cause of that problem about 90 percent of the time.
    You did check the cables running to the print head to be sure they are not binding the print heads free movement?
    Odd. Well the wiper woudlnt be stuck to the print head if you checked its movement.
    That is normally an easy problem to resolve.
    Let me know, I can E-mail you the information .
    PROBLEM:
    Printer error 07,007.49 - 07,008.41 - 07,009.42 - 07,010.43
    Printer Errors 07,007.49 ? 07,008.41 ? 07,009.42 ? 07,010.43 indicates that the printhead was unable to tilt normally on its axis.
    CAUSE:
    The following items can cause the four printer error codes listed above:
    · The printer was powered off in the middle of a cleaning cycle and the wiper has frozen to the printhead.
    · A Drum Maintenance Camshaft lobe is broken and holding the Maintenance Kit?s oil roller against the drum when it should be retracted to its home position.
    · Process gearbox not being aligned correctly as described in the service manual and in Service Bulletin 714.
    · A broken left or right printhead restraint.
    · Ink spilled in the roll block preventing the printhead from tilting forwards/backwards or from traveling left/right.
    · Ink or other debris under the printhead that do not allow it to fully tilt backwards or forward.
    · The printhead wiper assembly not being aligned correctly or ink spilled in the wiper tracks on either side of the printer.
    · The printhead tilt gear not being homed correctly.
    · The X-axis motor nose cone not being installed correctly.
    · The ferrite torrid on the printhead interface cable has slipped behind the printhead causing the printhead to bind when it tilts backwards.
    · The black plastic shroud on the back of the printhead is snapped off and binding the printhead when it tilts back.
    SOLUTION: Fixed! Did not fix.
    Make sure the printer components are manually homed per the Phaser 8400/8500/8550 Rev 3 Service Manual or WorkCentre C2424 Service Manual page 6-4. The information on how to manually home the printer is given below:
    Printer Component Homing Positions and Indicators
    After servicing the printer, manually set the following assemblies to their home position before powering on the printer. If the assemblies are not home, gears in the process drive assembly can grind or the printer can generate errors.
    · Printhead (tilted forward and disengaged from printhead tilt gear)
    · Tilt gear (disengaged from process drive train; arrows on left frame point to each other)
    · Printhead wiper (bottom of travel)
    · Process drive assembly (holes on transfix camshaft and drum maintenance camshaft line up with marks on frame, large gears within assembly line up with holes in process drive assembly housing)
    Wiper Assembly Positions
    When the wiper is homed, the wiper should be moved all the way to the bottom of its travel. When the wiper is at the bottom, you can easily remove the waste tray.
    Wiper Alignment Procedure
    1. Remove the printer covers using the procedures that begin on page 8-4.
    2. Remove the left printhead maintenance drive gear (see the following figure) by removing the e-clip from the drive shaft.
    . At the same time, rotate the left and right idler gears until the wiper is all the way to the bottom and the gears cannot be rotated further. Rotating the left and right gears together ensures that the wiper stays parallel and does not pop out of the belts.
    4. Replace the left drive gear and the e-clip.
    Homing the Head Tilt Gear with the Printhead Is in the Printer
    1. Remove the maintenance kit.
    Caution: The printhead also needs to be centered on its X axis before continuing. It cannot be against the left printer frame wall or right printer frame wall before trying to attempt step two. It will bind the printhead and cause it not to tilt if it is not centered correctly.
    To center the printhead for tilting, use a small flat blade screwdriver to rotate the X axis motor shaft to drive the printhead to the center of its travel.
    2. Insert a flat blade screwdriver into the end of drum maintenance cam shaft and rotate clockwise one revolution. If the printhead is engaged, manually assist the movement of the printhead.
    Note: The hole on the drum maintenance camshaft drive gear should be at the 6:00 position after the rotation. *Unless indicated otherwise by Service Bulletin 714 - Jam Open Front Cover (C3T) after Replacing or Reinstalling the Process Drive Assembly.
    Note: When the tilt gear is disengaged, the two arrows on the left side of the printer are pointing at each other.
    If you have difficulty in getting printer components homed, perform the following checks.
    1. Remove the left and right printer covers and ink loader per the instructions in the service manual. Look at the position of the wiper to the printhead. Is the wiper stuck to the printhead? (see Figure 1)
    If yes then do the following:
    Caution: The printhead may be hot, follow service manual procedures to make sure printhead is cool before continuing.
    a. Place your thumb on the printhead?s black plastic notch and push the printhead away from the wiper back towards the electronics module (see Figure 2). This will free the wiper from the printhead.
    . Roll the wiper to the bottom of its travel above the waste drawer using the gear on the upper left side of the printer to move the wiper assembly.
    c. Power the printer back on. If the printer is able to reach 5% to 10% warming up, turn off the power at the machine?s electronics module.
    d. On the front panel ?Standard Shutdown? will be highlighted. Push the OK key on the machine?s front panel to confirm this choice.
    e. After the printer has been off for 15 to 30 seconds, turn the machine back on to test and see if the error message has been removed.
    f. If there was excess ink on the faceplate of the printhead, the wiper will clean it off before it tries to do a cleaning cycle after the printer has warmed up.
    Caution: Do not try to manually remove the ink from the printhead by scraping the printhead faceplate or using any kind of solvents.
    If the wiper is not stuck to the faceplate of the printhead go to Step 2.
    . With power off, manually home the printer per the service manual Printer Component Homing Positions and Indicators topic. Then power the printer back on. Did the same error code appear? If yes, proceed with Step 3.
    3. Check for anything interfering with the tilt movement of the print head such as a broken print head restraint (Refer to PL 2.0 on page 9-7, Items 8 and 9 for printhead restraint part numbers). For the printhead restraint, look for cracks in the plastic under the mounting boss where the screw secures this assembly to the frame (see Figure 3). Also, look at the printhead restraint post on the backside of the restraint for cracks or uneven movement. If the printhead restraint is broken (either right or left side) it must be replaced. If it is not cracked or broken, continue to Step 4.
    . Check to see if the black plastic shroud on the rear of the printhead is broken off and causing impaired motion when the printhead rocks backwards to the electronics module. If it is attached, continue to Step 5. If the shroud has broken off, the printhead will need to be replaced.
    5. Check the Print head Interface Cable (PL 5.0 item# 6 on page 9-12) and verify that the ferrite torrid has not slipped down and blocked the print head from tilting back. If the torrid has slipped down, slide it back up to the top of the cable connector on the wave amp module (see Figure 4). This is not present on earlier units. If this torrid is dressed correctly go to Step 6.
    6. Check for ink spills around the Roll Block (see Figure 5 - refer to PL 2.0 on page 9-6, it is the square steel block with a hole in it to the left of item 7 in the diagram). If the printer was recently moved, it is possible that spilled or dislodged ink shards may be caught in head tilt gear or detent. Follow service manual roll block removal and reinstall procedure to clean up any spilled ink. If no ink spill is present and the roll block is installed correctly, then go to Step 7.
    7. Check the Drum Maintenance Pivot Plate (should be the black style) and check the drum pivot plate cam assembly for either a cracked/damaged cam and verify that the cams are lined up and point to the same clock point (one has not slipped on the shaft). For the Phaser 8400, check that the Drum Maintenance Pivot Plate is black plastic. If it is white the pivot plate needs to be replaced (see Service Bulletin 657 Revision 2).
    Also check the drum maintenance pivot plate cam assembly for cracked cams and verify that both cams are pointing in the same direction. The cam lobes should not spin freely on the drum maintenance cam shaft. If there are any problems replace the drum maintenance cam assembly.
    8. Check to see if the print head wiper assembly is aligned and not impeding the movement of the print head. (refer to PL 2.0 on page 9-6, Item 5) If it is, perform the Wiper Alignment procedure following the instructions in the service manual. If it is OK go to Step 9.
    9. Verify the Head Tilt gear is disengaged from the process drive train. When disengaged, the arrows on left frame point to each other. If not, rotate the Drum Maintenance Cam shaft (refer to PL 2.0 item# 11) 360 degrees clockwise and verify tilt gear is disengaged (see Figure 6). If held tilt is disengaged go to Step 10.
    10. Is the Process Drive Assembly properly aligned, with no damage to any of the gears per the service manual and Service Bulletin 714? If not, align the assembly per the homing procedure in the beginning of this service bulletin.
    11. Check the X-axis motor and nose cone for proper installation and operation or a grinding noise. Follow service manual installation procedure and use service diagnostics to test X-axis motor. if there is ink spilled under the printhead it will impede the X-axis movement, which can cause a printhead tilt error. (Refer to PL 4.0, on page 9-10, Item 12 for part location).
  • 50 Answers
Tryit, you're right! Your recommendation:
There is a print block located on the left side of the machine looking from the front. It is near the bottom of the machine, staineless steel, about 1 inch square.
This fixed the problem. This bushing really gets gummed up with wax. Fixing this yourself is not for the meek. I had to use plyers to finally get this bushing off. Then the fun begins with the clean-up. I used candle wax remover to clean-up the wax. If you attempt this be sure to put several pieces of paper between the print drum and the area where you are working to protect the drum.
Posted on Jul 18, 2011
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Even after numerous on off sequences I still get the same error code of xerox phaser 8560 error code 07 010 43.22845
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
Apr 23, 2014 | Xerox Phaser 8560DN Printer
Error code 13,327.42:458 How Can I Fix This?
13,327.42: The Printhead reservoir thermistor returned a bad reading, or the
reading was corrupted by ESD.
Try :
  • Are all components grounded properly?
  • Run the Printhead Reservoir Temperatur test. Did the test pass? If not replace the Printhead.
  • if it did pass check and reseat all wiring to the Printhead.
    Did this correct the problem? if not replace the print print head.
  • Go to www.iteminceonline.com and order a new one they will send you the instructions on step by step how to replace the print head and you can call them for free technical support. Goodluck
Oct 28, 2009 | Xerox Phaser 8500/DN Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Xerox Phaser fault 37,002,47:18505
37,0XX.xx Errors - PEST Faults
AC power supplied by power sources such as uninterruptible power supplies
(UPSs) or DC-to-AC inverter systems may not supply correct voltage to
properly power up the printer. Likewise, other devices sharing the same AC
circuit can cause AC voltage sags that cause the printer to fail its AC heater
PEST tests (Print Engine Self Test). The printer may produce any of the
following disconnected heater errors:
■ Printhead jet-stack 37,002.47 or 37,003.48
Error Messages and Codes
■ Reservoir heater, 37,004.40 or 37,005.41
■ Drum heater error 37,006.42
■ Preheater error 37,008.44
■ Ink melters errors 37,009.45 thru 37,013.40
The printer includes several heaters powered by AC. The printer itself can
power up despite insufficient or irregular AC voltage but it may fail its AC
heater tests. This is due the test not measuring sufficient current flowing
through the heater at the moment the test runs.
Devices sharing the printer’s AC circuit shared, such as a laser printer, a
coffee maker, or a space heater, may be placing heavy intermittent demand
on the AC circuit. This sudden inductive demand creates momentary AC
voltage sag that causes the PEST test to fail.
Verify the AC power source prior to troubleshooting these errors. For wiring
diagrams to aid in diagnosing PEST faults, see “Wiring Diagrams” on
page 10-1.
8400/8500/8550/8560 PEST Description
37,001.46: Generic PEST error.
Something went wrong during the PEST process.
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Mar 17, 2009 | Xerox Phaser 8400 Laser Printer
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
Mar 15, 2009 | Xerox Phaser 8550DX Laser Printer
Hi guitargurl:
Your printhead is stuck in the tiltposition,or is not able to tilt forward to the print position, due to another problem with a motor
7,010.43:
The printhead is stuck in the tilted position, or is not able to tilt forward to
7,011.44: This is a soft fault, and will not halt the printer.
7,012.45: The drum transfix home sensor is still in a not homed position, after the
return home motion has been completed.
7,014.47: The printhead is not locked in the head tilt restraint spring.
7,015.43: The head tilt restraint spring is out of place.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Reboot the printer.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
manually push the printhead right to left.
Clean the
printhead area.
Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot
the X-axis
drive.
5 1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the
gears.
Go to Step 7.
7 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
2. Did the test fail?
Replace the
wiper drive
clutch.
Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Replace the exit
module
assembly.
Go to Step 9.
9 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
Jan 08, 2009 | Xerox Phaser 8860MFP Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
On the machines left frame, about midway back near the bottom there is a stainless steel block that the print head shaft runs through.
Pull the spring assembly off and locate that up and to the left.
The print block is about 1 inch square,and is most likely contaminated with some ink and needs to be removed from the shaft and cleaned. Also remove any loose ink around the print block that you can.
May 07, 2008 | Xerox Phaser 8500/DN Printer
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser  8500/DN Printer Logo
2,906 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
