Question about Dell Printers:Dell MFP Laser Printer 1815dn
Cannot scan to PDF. I have Dell 1815dn and cannot scan to PDF, when using "windows scan and fax" on my PC, only JPG, PNG, TIF, BMP. I cannot scan multi-page docs
4 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: how do you scan a paper to a PDF file on dell
Scansoft (or Nuance) PDF Converter 3 is a useful utility for converting documents to PDF files
Posted on Mar 02, 2010
jas247
  • 844 Answers
SOURCE: my laser mfp 1815dn is reducing the size of the
Welcome to Fixya!
Adjust the Scan setting to the defalult/appropriate resolution. See guidelines below.
Documents:
300 dpi black-and-white or 200 dpi grayscale or color
Documents of poor quality or that contain small text:
400 dpi black-and-white or 300 dpi grayscale
Photographs and pictures:
100-200 dpi color or 200 dpi grayscale
Thank you for using Fixya. Have a great day.
Jas247
Posted on Jul 12, 2011
SOURCE: dell 1815dn - when faxing,
Here is what's causing the problem:
1. Charge - Print Quality (PQ) -- The charge roller evenly distributes a negative charge on the photoconductor (PC) drum. This evenly distributed charge acts as the film that is discharged (exposed) by the laser to create the latent image.
a. Print Quality effected: Faint, Entire Black background, Grey Fog/Haze
b. Parts Involved:
i. Drum -- A drum cartridge is coated with a photoconductive material that allows electricity to pass when exposed to light. As an example of why this can be the failure, if you leave a drum out in light long enough, you will get dark backgrounds or just black pages. However, drums do wear out over time too; specifically the photo material the drum is coated with. As this degrades, more of the positive electricity on the inside of the drum gets through and grabs toner, as if the laser wrote to every square inch of it. A damaged or defective PC drum can cause black streaks/lines, voids, speckles and various other print quality problems.
ii. Charge Roller - Also known as the BCR or Bias Charge Roll. The charge roller pulls double duty. It energizes the outside of the drum with negative energy and as a result it cleans any previous latent images. If the charge roller were failing to energize either due to the HVPS or the charge roller itself, it wouldn't clean any previous unused toner deposits from the last revolution would start to accumulate and appear on paper more and more causing haze. A missing charge roller causes completely black pages.
iii. HVPS - High Voltage Power Supply -- Responsible for charging components such as the inside of the drum, the charge roller, and transfer roller. If the HVPS does not give enough to the charge roller it can fail in erasing the drum, causing entirely Black pages to be printed.
Hope this helps.
Posted on Aug 03, 2011
Windows 7 driver
The HP website below has a driver that will allow you to scan from "Scan" software button selections within "Windows Fax and Scan" and HP Photo & Imaging, however the HP Director software will not work (this allows you to configure the hard buttons on the scanner). no work around as of yet (and by now I would not expect one). These will also LIMIT to image type output files (*.bmp, *.jpg (or *.jpeg), *.png or *.tiff). No PDF Support.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&os=2030&product=73488&sw_lang=&
Jan 06, 2014 | HP ScanJet 3500C Flatbed Scanner
There is no option to scan as pdf on my 4625 HP scanner (tif, jpg etc are available), how can I add pdf?
The HP SCANNER SPECS say: Scan file format Bitmap (.bmp), JPEG (.jpg), PNG (.png), TIFF (.tif), PDF (.pdf), Searchable PDF (.pdf), Text (.txt), Rich Text (.rtf).
That means it is supported. What you can try is to try and uninstall ("Programs and Features in Windows) the Adobe PDF program and get the free one to install again from: http://www.adobe.com/products/reader.html
If it still doesn't work (links itself into Windows and the HP software), try reinstalling the HP software or go to HP.COM and you can download the latest full-version file for your 4625 printer.
Dec 02, 2013 | HP DeskJet Office Equipment & Supplies
How to operate the cx6000 scan with Windows 7 (64 bit) to create a PDF file? I can use Windows 7 & cx6000 to create jpg, tif, png & bmp files, however, is there a way to create a pdf file using...
http://majorgeeks.com/download.php?det=5622
Sumatra PDF is a slim, free, open-source PDF viewer for Windows. It's designed for portable use: it's just one file with no external dependencies so you can easily run it from external USB drive
Sumatra PDF Portable enables you to read and modify any PDF according to your demands. This tool is the lightweight Sumatra PDF packaged as a portable app, so you can view PDF files on the go. You can place it on your USB flash drive, iPod, portable hard drive or a CD and use it on any computer, without leaving any personal information behind.
Sumatra PDF is a slim, free, open-source PDF viewer for Windows. Sumatra has a minimalistic design. It
Mar 14, 2011 | Computers & Internet
How can I compress a scanned document so it isn't so large ?
The scanned image could be a TIF or BMP file, which can be quite large.
Download the FREE 'GIMP' (Graphical Image Manipulation Program), and install it.
Load the image. Crop it (to reduce size). Use 'Save As' to save as a GIF or JPG or PNG file,
which automatically compresses it.
Mar 02, 2011 | Dell 810 All-In-One InkJet Printer
How to scan a document where it doesn't take so much space? When I scan a contract of 8 pages it is like 13MB. I need it to be smaller like in KB.
One of the main ways to reduce document size is to consider what format you are saving them as.
I just did a sample scan and the following are the results of different formats:
.png - 88 KB
.gif - 108 KB
.bmp - 192 KB
.tif - 196 KB
.jpg - 1.14 MB
As you can see the JPG file is over 10 times larger than the PNG file.
Also make sure that you do not scan as a color scan if it is not needed. The above scans were all scanned in black & white.
I hope this has helped you. Thanks for using Fixya.
Wayne
Jun 27, 2009 | HP Office Equipment & Supplies
Hi,I have got a Canon,smartbase MPC 400 printer/scanner. My question is: How can I scan a document straight to a PDF file,because it only gives me options for TIF,BMP and JPEG. I have downloaded a TIF to...
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Nov 13, 2008 | Canon Office Equipment & Supplies
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Jun 14, 2007 | BenQ 5000U Scan to Web Scanner
Photo formats
iPod Main | iPod Q & A (Main) | Next Q & A Section Q & A: iPod Q & A: Transfer & Connectivity (6/6) What graphics formats does the iPod photo/"Color" recognize? iPod nano? According to Apple Support Document #300241, on the Mac, iTunes 4.7 (and higher) can recognize and prepare "JPG, TIFF, PICT, GIF, PNG, JPG2000 or JP2, PSD, SGI, and BMP" images for display on the iPod photo/"Color" and iPod nano. On Windows, iTunes 4.7 (and higher) can recognize and prepare "JPG , JPEG, BMP, GIF, TIF, TIFF, and PNG" images from "Adobe Photoshop Album and Adobe Photoshop Elements" for display on the iPod photo/"Color" and iPod nano. However, in disk mode, you can copy any type of file to the iPod for transport to another computer.
Sep 29, 2005 | Apple iPod nano
762 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
