Question about American Standard Colony 3275.505 099 Chrome/Brass Mixage Soft Two-Handle B...
I have an American Standard Colony? bathtub faucet set that has been leaking at the spout. I thought the reason for the leak was the seats and rubber washers needed to be replaced. After doing so I still have a leak. I have double checked the seats are not cross threaded and the washers are secured by the screw. How likely is it that this be caused by the stem assembly being worn out? It looks like it may the original stem assembly. Sid
  • 139 Answers
Try checking to see if the seat is tight enough ..if this faucet uses old scool washers and seats the only way around the seat is the threads ...so try to tighten a little more or try beveled washers ..to see if that works ...the tub when you turn off will normally take 1 min to stop dripping because of the water in the shower tube will drain after shut off..let me know ..good luck../joe/
Posted on Aug 28, 2010
  • 744 Answers
Check these items:
1. If you installed new faucet seats, did you add a little pipe joint compound to the threads before installing them?
2. Make sure the shower diverter is in the off position and you're not seeing water leaking from the spout that could be coming from the shower pipe or residual water from the shower head.
3. Make sure you have the correct faucet washers - some or tapered and some are flat and must fit the stem counter bore correctly and that the counter bore isn't damaged or the stem shaft isn't bent. Make sure the waskers are the correct hardness.
4. Make sure the screws that secure the faucet washers are tight, but not too tight. It doesn't hurt to add a little pipe joint compound to the screws.
When dishwasher is running, water leaks under base of our American Standard Colony model soft two-handle kitchen faucet into cabinet beneath sink
Is there an air gap next to the faucet that is leaking. If so, it is probably clogged. Pull the cap off of it and clean it out. This is what it may look like before you take the cap off.
b7ookdehz3uf293omx2ye0fveemyn-clsycdlpsjpi2zdtnzgmj_hhepw5uyprhfsmyzy7tnfmt6uzrk1edu-duydxm839afzrsaplofdfdjymmjvj8xncabtrcoevtu5jguw1elsvyttyypguy-89xi_btsfhkvzgvdbfbda26sii9hwd8sgq
Jan 16, 2011 | American Standard 4275.550.002 ColonySoft...
American Standard Colony Soft gooseneck kitchen faucet leaks base
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
Jul 13, 2009 | American Standard 4275.550.002 ColonySoft...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
How to replace sprout seal kit?
After you remove the handle, the chrome cap should either snap or spin off.It also may come out with the cartridge... There are 3 screws that hold the cartidge in the faucet...take them out and you should be able carefully work the faucet are off of the core of the faucet. Put a little cooking oil on the o-rings after you install the new ones... just to allow the faucet arm to slide on without damage... Hope this gets you dripless!! Let me know if you have a question. K
Jun 05, 2009 | American Standard 4175.200.002 Colony...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Faucet leak from the connection with spout.
Return the new faucet for another one. The o-rings in the base of the spout are leaking. Either installed wrong at the factory or defective rings.
Don't fight with it, trade for a different one.
Please rate this answer and Good Luck, Phil
Dec 29, 2008 | Plumbing
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
American Standard Colony 3275.505 099 Chrome/Brass Mixage Soft Two-Handle B... Logo
292 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
