Question about Kenmore Elite Oasis 27052 Top Load Washer
What does F1 mean - Kenmore Elite Oasis 27052 Top Load Washer
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 16, 2010
What is f1
if its a whirlpool built product it usually means that the main control board has failed... what brand is it?
Jul 24, 2016 | Washing Machines
Tip
What the F1 code means on your OVEN
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
on Aug 05, 2011 | Ovens
WHAT DOES FAULT F1 MEAN?
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 08, 2011 | Whirlpool Dryers
Toploader kenmore elite oasis is showing F1 code for error. I do not have an owners manual. What does F1 mean?
Gene
Aug 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Stove error f1 kenmore elite model 790.75902990
Aug 12, 2011 | Kitchen Ranges
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Hotpoint ultima
F1 means short circuit motor triac.
You need to call an engineer.
Oct 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
What does F1 mean?
F1 means you either need a new touch pad or a new control board. Usually it's the touch pad. Hope this helps, APP tech http://www.AppliancePartsPros.com
Jul 30, 2006 | Kenmore 45702 / 45704 / 45709 Dual Fuel...
Kenmore Elite Oasis 27052 Top Load Washer Logo
23 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
