Question about GE Monogram Side by Side Refrigerator
My GE Monogram side-by-side built in refrigerator is only 1 1/2 years old. There is a fairly loud "knocking" sound (about 8 quick knocks) about every 15 minutes. Any ideas of what it is?
I had a distinct "knocking sound" coming from the compressor behind the top panel of a side-by-side Monogram built-in. It was quiet sometimes and very loud at other times, and everything in between. I waited until it hadn't run for a while (too hot) so I could get my arm/hand behind the compressor to check the fan. I found the fan blade to be hitting the cowling when I spun it with my fingers. I attempted to reposition the fan but I made it worse when the fan came on--so while the fan was running I pushed on one side of the fan blade assembly to better center it in the cowling until the sound disappeared. Not a very sophisticated solution, but effective none the less. You cannot even hear the refrigerator running now. The fan blade will move forward/back on the drive post--it appears to be designed this way--so your issue is getting it left/right centered.
(Note: the fan blade is a very soft plastic so there is little chance of injury. I used a long heavy-duty screw driver to push and reposition the blade next to the center drive post only. You have more of an opportunity to burn yourself on the compressor and lines, than hitting the fan blades with your fingers (it's a very low torque fan), so wear a long sleeve shirt.
Posted on Jun 16, 2012
  • 139 Answers
Sounds like the compressor may be to blame listen closely to the sound an where its comming from ..then let me know../joe
Posted on Aug 28, 2010
  • Hefty2000 Nov 12, 2010
    I also have a GE monogram side by side ziss460dx or similar..... it has exact knocking problem... although maybe less frequent than each 15 minutes. The knocking is coming just below mid point of freezer section, near isolation (wall) from refrigerator section. I once read there are a series of dampers or vent covers that actuate from time to time btwn Freezer and Fridge... i wonder if these are small servo/stepper motor controlled flaps and one is jammed up?
    any experience with that?
    thx
    steve
  • rlschwandt Jan 29, 2011
    I also have this problem. Has it been resolved and how? thx
My KSRP25FNSS makes a strange knocking noise at each compressor shut down and sometimes during running. The noise is always a series of 5 knocks, very loud, in quick succession that telegraphs though
By you discription above it sounds like one of the three spring the supports the compressor pump has failed or broke. Now the only fix is to have the compressor replaced, but if the unit is still cooling, currently its a noise problem only. I hope this helps you. If this is still under a warranty, ask for it to be checked as if in warranty it needs to be replaced. Good Luck
Jan 04, 2015 | KitchenAid KSRP25FNSS Side by Side...
Mechanical wood pecker in my Monogram Refrigerator?
HELLO!!!
HA HA HA NICE JOKE !!! HMMM TRY SWITCHING IT OFF FOR FEW HOURS AND CLEANING THE TRAY AND FREEZER!!
Dec 31, 2007 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
What does compressor getting noisy on ocaisson mean? Do I need to assume failure is immenient or could it last a while longer?
It is hard to say how long any appliance will last, but I would not replace solely for a noisy compressor. Most all compressors with age will get noisy on start up and shut down. If there is an espically loud knock on shut of check the mount bushings or for broken/lose mounting hardware
Sep 17, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
How often are you supposed to change the filter? (GE Monogram)
GE recommends once a year for the water filter for light use and twice a year if used heavily.
Please take time to rate this fixya.
May 11, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Mar 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE Monogram Side by Side Refrigerator Logo
326 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
