Question about Comfort-Aire RAD-81 Air Conditioner
When i first turn on my air conditioner it works fine but then when the compressor turns off it never comes back on the fan just runs and then it blows the reset button on the plug in do you have any ideas of what might be wrong
  • 139 Answers
It sounds like your compressor start capacitor is to blame ..to get to it the front plastic cover needs to be removed ..remove the control panel to see the capacitor ..its round or ovel /silver/ an wires hook to the top of it ..look to see if the top is bulging or leaking fluid ..this helps the compressor /fan /start ..let me know.. an good luck../joe/
Posted on Aug 28, 2010
5 Suggested Answers
SOURCE: My air conditioner doesn't blow out any air.
If this is a central air unit & you\'re talking about the fan on the outide of the house the problem may be that you are only getting 110 volts to the system side of the contactor. If you have the tools & know how you can check this yourself. If not, time to call a repairman.
Posted on Jun 01, 2007
22yooper
  • 828 Answers
SOURCE: air conditioner
If the fan blows cold air the compressor is already on.
Posted on Jul 18, 2008
awcforever
  • 359 Answers
SOURCE: lennox air conditioner is blowing hot air
Check your coils for ice, check your breaker and fuses for condensing unit, and is your condensing fan running? If not, you either have a bad fan motor or capicitor. After you hit the button, and wait for it to time out, (you should hear a click) take a butter knife, and spin the fan if it is not moving. If the fan start spinning by itself after your assistance, you have a bad capacitor
Posted on Jan 29, 2009
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
My a/c unit was working fine for the last couple of months. Unit would turn on run compressor would shut off fan would shut off a few minutes later. However approx. 11/2 weeks ago I noticed that when the...
this appears to be a stuck relay or contactor . follow the wire back from the fan and locate the contactor or relay slp it and see it it comes lose. ?? this does not mean it will solve the problem as you will still have to repalce any part that is causing it.. Hope this helps let me know Jon
Jul 25, 2011 | Frigidaire FAH125N2T Air Conditioner
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
Outside fan not running, inside unit running fine. Compressor was running this morning, but no longer. Replaced fan motor, turned power back on, now fan or compressor not running. What else can be checked?
There may be a manual reset high limit... look for a red button on a round part hooked to the small copper line and push it in hard...
Also the compressor may have kicked the overload and needs a few hours to cool and it reset, that is interanl insdie the compressor.
Contactor may also have went bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 25, 2010 | Goodman Heating & Cooling
I have a Dometic rooftop Air conditioner in my RV When I turn it to low medium or high the fan run the same speed and when I turn it to AC it will run for about 5 min then the fan will shut off but the...
Bad fan motor I suspect The windings are bad causing the motor to over heat sending the motor into thermal overload. would suggest the replacement of motor. Good Luck on repairs
Dave
Sep 14, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on
do you know if the fans are running constantly? and if so when the compressor comes on it trips out and the fan remains constant? i would like to know the running amps are they correct.
Jun 08, 2009 | Heating & Cooling
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
My problem is the fan never goes off runs 24-7 and you can hear the compressor kick in from time to time. Is something wrong or do they all do that for a roof top unit? Any help on this one?
Frank
Jul 05, 2008 | Dometic Rooftop RV Air Conditioner
Compressor tries to turn on but cant.
Try changing out the start up and run capacitors for the compressor.
Jun 24, 2008 | Coleman Mach 15 Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Comfort-Aire RAD-81 Air Conditioner Logo
112 people viewed this question
Top Comfort-Aire Heating & Cooling Experts
Ottoniel
Tim Whalen
Are you a Comfort-Aire Heating and Cooling Expert? Answer questions, earn points and help others
