Question about Kodak EasyShare C643 Digital Camera
Kodak C643 died...
Help! During my vacation my Kodak C643 died! I have tried changing the batteries and the power cord and nothing works....have I lost my pictures forever?
    Genius:
  • 1,554 Answers
The pics on the memory card should still be fine.
you will have to purchase a memory card reader
they are inexpensive ,for example a usb memory sd reader goes for around 25.00
be sure it can read sd memory
the memory card is ejected next to the batteries.
http://www.dpinterface.com/reviews/canon-powershot-a430/canon-a430-side1.jpg
when you insert them in the reader it will read as another drive and you will see your pics.
Posted on May 07, 2008
My c643 does not come on at all. I put new batteries in and nothing.. what should i do?
i find only certain brands of batteries will work, keep trying and maybe when you first turn it on after installing new batteries turn it one clockwise click (not sure what the icon is that it will point to) and see if that clears it up.
Feb 01, 2010 | Kodak EasyShare C643 Digital Camera
Kodak easyshare c643 - batteries are fresh, but it won't power on. The "on" light turns green then flashes red.
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 20, 2009 | Kodak EasyShare C643 Digital Camera
C643 won't turn of, screen is black
The problem you describe is frequently the result of dirty/corroded battery contacts in the camera. Try removing the batteries and cleaning the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue left from the cleaning, then replace the batteries. Hopefully all will be well.
If the cleaning doesn't work you might want to check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 05, 2009 | Kodak EasyShare C643 Digital Camera
Kodak C643 wont respond .
Changed batteries.the new ones were "no Good"installed another set,camera works grate.thanks.dbuggerhill
Nov 14, 2008 | Kodak EasyShare C643 Digital Camera
Kodak C643..what is wrong?
i bought some nimh rechargeable batteries a couple years ago and they still work to this day. im on my second camera with them and it does that to me when the batteries are dead. try opening the battery door when it does it and then close it and try turning it on again. if it does come on then its the batteries.
Aug 30, 2008 | Kodak EasyShare C643 Digital Camera
Another question...
I haven't any direct experience with that model to really know,
but the 16meg memory in the camera is listed to be to be flash in some specs I read ,which makes sense.
but if you have to replace the main board then the pics are gone.
May 07, 2008 | Kodak EasyShare C643 Digital Camera
Camera won't turn on with new batteries or power cord
I heard from another posting on here and the answer, that someone took fine sandpaper and cleaned off the terminal ends of both battery and camera and blew out the dust particles from that before replacing the battery, then then camera worked. I have yet to try it with my Kodak camera that is 2 years old and suddenly died too! The batteries are fine and work in other cameras.
Nothing works
Remove batteries and clean contacts both inside the battery chamber and on the chamber lid/cover.( use something slightly abrasive ). If this doesnt help replace fire fuse situated on the main pc board ( underneeth rear cover ).
Aug 27, 2007 | Kodak EasyShare C643 Digital Camera
Kodak EasyShare C643 Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
