Question about Maytag Refrigerators
I have a maytag side by side refrigerater psd262lhez that is not cooling or freezer not freezing. what causes this
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
Freezer side seems to work but the refrigerator side isn't
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Sep 11, 2011 | Maytag Refrigerators
Refrigerater not staying cool 52 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Maytag Refrigerators
My 8 year Maytag refrigerator stopped cooling and now the freezer is no longer freezing - are there any minor causes I can check - any help would be great
if the freezer is warm check the start device on the compressor,part number 12002784.the compressor won't run and you'll hear a clicking sound coming from the back every 3 to 5 minutes
Sep 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
REFRIGERATER SIDE IS NOT COOLING BUT THE FREEZER IS WORKING
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
qreq
May 10, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
I have a maytag side by side refrigerator freezer and the lower part of the freezer where the cooling coils are freeze up and won't allow the air to cool the refrigerator side.
Sound as though you need a defrost timer that is located around temp control and light in fridge side.If it is faulty it will not go into a defrost making the freezer ice up and cause alot of trouble.hope i helped thanks:)
May 12, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
MY Maytag Wide by Side freezes in the produce drawers.
When a unit freezes in the lower drawers this is usually due to a thermistor which is not functioning properly. If you can provide your model number I can try to locate your schematic to your unit showing the thermistor that you would replace to alleviate this issue. I will await your reply as to the complete model number of your unit.
p.s if you had ice up the top of the unit as well then you would look at the damper door otherwise known as the diffuser door in some units or the control for the door as the problem area in your unit.
Thank you,
Rick
Jan 21, 2009 | Maytag 26 cu. ft. Wide-By-Side...
Refrigerators Logo
156 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
