Question about Nor-Lake Norlake Refrigeration 4' x 6' Kold Locker Walk-In Cooler - 6' 7'' High w/Floor
Freezer not doing the job
My friend have ice cream van he is freezer not cold like used to be temprature _12 but should be _28 now ice cream melted .what can do to hellp him
  • 828 Answers
Step by step look for the obvious such as; is the condenser clean on the unit outside the box, is the condenser fan motor running, is the coil inside iced up. These are common problems with freezers.
If the coil is frosted over the problem may be related to the defrost timer. Rotate the timer as per the arrows to the defrost position to defrost. This should cause the coil to defrost. If this does defrost the coil replace the timer.
If the condenser fan motor does not rotate with the compressor running, rotate the fan blade manually, if it is the least bit tight the bearings may be dry or gummed up, oil the motor with non-detergent oil SAE-20.
Posted on May 07, 2008
Freezer makes ice cubes but ice cream Melts.
ice is made at 30 degrees ice cream is not hard till about 3 degrees.
freezer not cold enough.
Jan 24, 2017 | Refrigerators
What setting do I use to make the freezer freeze food
When you are freezing something, set your freezer on its highest setting. However, if you are going to leave your freezer empty for a long time, you should change the setting to a lower one. Here's a great tip for ice cream: place a tub of ice cream in a ziplock bag before putting it in the freezer; it prevents freezer burn. You know when your ice cream gets so cold, it's hard to scoop out? Doing this stops that, it's keeps the ice cream just soft enough for easy scooping!
Sep 28, 2014 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have an Amana side by side frig and the freezer is not keeping ice cream cold. The refrigerator side seems fine. The freezer side is set to 7 but it no longer clicks like it used to when you turn the...
If you do not have guages (freon) and have a licens to proforme this type of work you will need to have someone qualified in this area to varify.You can call sears home repair @ 800 469-4663
Aug 05, 2010 | Amana ARS2464B Side by Side Refrigerator
Sorbet not freezing
If it is not freezing, I would suspect you didnt use enough salt. Salt melts the ice and makes the water colder. You need lots of ice, the finer crushed the better, and salt. Do not bleed off the cold water, that is where the action is.
Hope this helps.
Aug 03, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
The freezer is not getting very cold - ice forms but ice cream stays very soft
check the temprature and turn it off for some time and read menual for temp.
Jul 25, 2009 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge freezer temprature/hot doors
if your talking about the post between the doors its supposed to be hot its to keep the gaskets dry but you can clean the coils on the fridge if you haven't for awhile that will help keep them the right temp as far as setting the temps i always using your milk and ice cream every one knows how they like their milk and you don't want to have to dig your ice cream out with a chisel
Feb 16, 2008 | Refrigerators
Ice cream has ice crystals in it
Ice crystals are more prevalent in homemade ice cream because it takes longer to freeze the mix. When you can flash-freeze the ice cream to very low temperatures very quickly, there is less time for the molecules to melt and refreeze, which causes crystal formation.
Here are some of the useful tips:
1.) When the ice cream is done, transfer to the coldest part of the freezer as quickly as possible
2.) Pre-freeze the ice cream bowl before using, and pre-freeze the storage container before putting the ice cream in it and into the freezer
3.) Make sure the mix is very cold before using the machine. Maybe put the mix in the freezer for 15 minutes before starting the machine, so that it will finish faster
Hopefully this information helps a lot.
Jul 09, 2007 | Rival 8550-X 5 Quart Ice Cream Maker
Refrigerators Logo
81 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
