Question about Whirlpool ED2SHAXM Side by Side Refrigerator
Freezer is producing ice but wont release it into the ice bucket. Model # ED22CQ
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Samsung double door model SR-L709EVSS - Freezer is chilled but does not make ice. Ice/frost packs on the wall of the freezer. As soon as I open the freezer door the temp defaults again.
Hi.. this can be caused by a number of things, however, that packed ice on the wall leads me to think this is a frozen solenoid on the water intake..
The most difficult thing about the fix, is where to put the contents of your freezer for overnight.. check with your neighbours, or get a large cool box.
the fix is to simply defrost the freezer THOROUGHLY.. it cannot be rushed with a scraper as the ice is within a closed valve and possibly backing up the water pipe by an inch or so.. make sure that the ice bucket fill wire is up, so that it does not try and make ice when you let it thaw properly overnight, dry it thoroughly and then set the freezer temperature to it's warmest setting for a few hours, then a little cooler, and so on, until you get to the desired temperature.. then drop the ice gauge wire to trigger ice making.. check back in a few hours to see if any has been produced
When you return the food, please pre-sort it, into shopping bags, each bag representing a shelf so you can fill the freezer swiftly.. then the ice that's made won't melt slightly, and then refreeze, sticking it to the ice bucket.
Apr 23, 2017 | Samsung Refrigerators
The fan inside the freezer won't run,freezer freezing up,no air going into fridge model ed22cq
OK, if the fan is not working and you have ice buildup on the coils, you will need to replace the defrost thermostat and the fan.
Here is the thermostat to order.
Here is the fan to order.
Nov 28, 2012 | Refrigerators
ICE MAKER
to solve the frozen food problem, turn the temp back to 4. this should be the factory recomended setting. the only dispensing crush ice is probably a bad solinoid. you will find this behind the back wall. it engages to lift the thin metal rod on the bottom of the ice bucket to dispense cubed ice. and the ice being frozen in the bucket is probably a bad ice flapper in the door. it's letting warm moist air into the ice bucket that is freezing
Apr 23, 2010 | GE GSH25JFR Side by Side Refrigerator
Ice maker wont work
If the ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
If the ice maker is producing ice poorly.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve. First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 27, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice maker in refridgerator freezer won't make ice. It seems as if the water is going up into the freezer but no Ice is being produced. The ice tray has frozen ice in it, but it will not dump it in the ice...
Sometimes icemakers get all frozen up, such that the motor cannot turn to eject the ice. Also, in some cases the water supply line freezes up, although that does not sound like your problem.
Try leaving the freezer open to defrost it manually and see if it starts working by itself. Also, the icemaker motors can and do fail. In some cases you smell an acrid burning smell when the motor fails.
Oct 16, 2009 | Kenmore 50522 / 50524 Side by Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice Maker won't produce ice through the door
You either have a bad interface board ( touch board ) or a bad main control board . You would have to go into the test procedure from the touch board to determine which is bad . The more I think about it though , I tend to lean towards the main control board . Once you get into the test mode , 0 and 4 would test communication between the 2 boards .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
Kenmore Elite Model: 106.5896.701 - Ice cube motor not turning
If you are describing the ice dispensor motor then you will find it under the ice bucket. If I remember correctly there will be 2 1/4 inch nut screws about the 3rd shelf on the freezer door. You will have to look up at them. The white mold that the bucket sits on. This is inside the freezer door. Those motors burn out frequently because ice will get jammed in ice bucket or bucket will freeze up due to flapper on dispensor isnt sealing correctly. Then we humans will continue to push to dispense and it wont move and burn up the windings. If you can work upside down you can fix this.
Jun 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not producing ice
Most automatic ice makers have a lever (looks like a piece of wire) that is prevented from being in the down position when the bin is full. This stops the ice maker from producing ice when not needed. The lever can also be lifted manually to a locked up position which turns the ice maker off as well. If the lever is in the up position, simply press down on it, it should release and return to the down position. Once down, the ice maker will begin producing ice again (the unit will have to complete its cycle before you see any ice, normally a couple hours or less). Hope this helps.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
Whirlpool ED2SHAXM Side by Side Refrigerator Logo
170 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
