Question about Mtd 22" Yard Machine Push Mower
Diagram Yard Machine Push Mower Model # 12A-238B062 I think it is missing a bolt on right front carb area. I have taken off plastic motor cover when I noticed carb movement and believe there is bolt missing in front to mount.
  • 1,631 Answers
Check this link out, it may help you?
Operators Manual
Posted on Mar 09, 2015
5 Suggested Answers
  • 376 Answers
SOURCE: Carbaeurator problems - 22" Yard Man push mower
That is the intake tube. You have to remove the rewind starter housing and the armature (what the sparkplug wire is hooked to) and unscrew it. IfI knew the engine model and type numbers, I could tell you the part number for the tube. They are located around the spark plug and stamped into the cover. Model-Type-Code.
Posted on Jun 18, 2009
woobie dog
  • 1273 Answers
SOURCE: Yard Machines 22" push mower
Hello, W/D here.
2 suggestions: 1. Check the fuel cap for pluggage, paying particular attention to the pinhole vent in the cap, and 2. Clean the air filter. A plugged (or nearly plugged) filter can also cause these symptoms.
Best regards, --W/D--
Posted on Feb 14, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Have a Yard Man 21"
Hi ccidb11..
I would recommend that you spray the shaft and flywheel with penetrating oil, or WD40.
Then tap the crankshaft, with the nut loosed so it acts as a flat surface to tap on with a hammer.
What you need to do is put your puller on the flywheel and tighten it down really tight, then with a hammer hit the end of the puller (where the wrench goes) a couple of times, then retighten your puller again, and hit the end again.
You will do this until the flywheel will pop off...
Please take time to rate me
Posted on Jun 27, 2011
cardenderek
  • 783 Answers
SOURCE: I purchased a Yard-Man Model 12A-26MB055 1602930
Use this site. Enter model number and serial number and you can download instantly i believe.
http://manuals.mtdproducts.com/mtd/Public.do
Best Reguards, FixYa.com
Posted on Jul 27, 2011
Removing the recoil or housing from mower
If there is any decorative plastic cover then remove that first; should just be a couple of 1/4" bolts. Depending on your engine, you may have to remove the gas tank too. Then, if it's a Briggs engine, it will have 4 bolts holding the blower housing on (3/8"); two up front and two in the rear. Then the blower housing should just lift off. Here is an excellent video on the subject. Best of luck to you: http://www.youtube.com/watch?v=iczCZaRiR0Q
Oct 08, 2011 | Mtd 22" Yard Machine Push Mower
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
How do u change the belt on a self propelled MTD Model #12A-268B352 push mover
Please follow this link to the MTD website which will give you step by step instructions. I hope this works for your model as well. Best of luck to you and "Happy Motoring". James
http://tinyurl.com/3vpwdts
Jun 27, 2011 | Mtd 22" Yard Machine Push Mower
Pull cord want retract so i can start mower got plastic cover off but the cord is in medal housing which is held down with three rivets how do i get it off to fix cord.
You have to remove the motor cover that the starter housing is riveted to. Usually three or four bolts around the perimiter of the housing and it will slide off with the starter housing.
May 05, 2011 | Mtd 22" Yard Machine Push Mower
I have got a MTD push mower Model no, 11A41MB029 SerialNo. 1i158K70951 It starts just fine and Idles fine too. The problem is that is does not speed up when cutting grass. This model has a choke if...
There are 2 things and whitch carb,one has a diafram ,I dont think that is yours, your has a bowel on the the carb take 7/16 wrench remove your bowel on the carb clean it out,and some the bottom bolt is your jet you will have to clean it out,
Aug 13, 2010 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
22" Yard Machine Push Mower: The pull is won't pull and it seems that the engin...
check under deck and make sure blade not bent or something bending it-if good try to move blade back and forth if stuck solid than at pull cover look for any screws or bolts loose in area jamming movement if good internal failure possible valve/crank or piston damage
May 05, 2010 | Mtd 22" Yard Machine Push Mower
Rope locked up
if you hold the spring in your left hand and wind it to the right it sold be right but you have to make sure it is small enough to go back in it spot
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Briggs & Stratton Quattro lawn mower engine. Runs rich and unevenly. Suspect carb and have used sprey carb cleaner. Any suggestions??
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Jun 05, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
213 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
