Question about Mtd 22" Yard Machine Push Mower
What spark plug n gap do I need for bolens mtd 22 in 158 cc 5.00 Briggs & Stratton push lawn mower?
  • 1,631 Answers
This link may help you?
Operators Manual
Posted on Mar 09, 2015
  • 75 Answers
SOURCE: gap setting for briggs-stratton 6.5 lawn mower
I believe it is 0.040 on a regular spark plug gapper
Posted on Nov 07, 2009
smjdragonfly
  • 79 Answers
SOURCE: have Bolens series 080 22
When you take off the carburetor initially, you should change the gasket if it tears or just old looking, your problem is in the carburetor, probably. Take it apart remembering where the parts go. There are some diaphragms or gaskets and screens on some, tiny jets and such that are inside the little "bulb" or bowl, that can usually be taken off with a 10mm wrench. They also have little fiber gaskets and a bowl gasket or o-ring that must be in great condition with no trash. Clean off with starter fluid or carburetor cleaner.
Posted on Jun 18, 2009
kel1guy2002
  • 3740 Answers
SOURCE: need repair manual for briggs
After a very extensive cross reference session your engine is model number
10H902-0285-E1 (not provided by you so it took a while)
Your engine is covered in this repair manual:
http://www.mymowerparts.com/pdf/Briggs_&_Stratton_Service_and_Repair_Manuals_Spec_Charts/270962%20Single%20Cylinder%20L-Head%20BRIGGS%20&%20STRATTON.pdf
If there is a problem that your having I can help you if you would just elaborate. I could save you lots of time. The 2 most common failures of this engine is on the carburetor. The parts that fail are the diaphragm (Item 394) and the primer bulb (Item 976) of this link:
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=10H902-0285-E1&dn=57160004
Carb data is in section 3 of the first link.
Thanks for choosing FixYa,
Kelly.
Posted on May 10, 2011
  • 407 Answers
SOURCE: I have a Bolens 22"
There will be a small screw near the carb with a spring around it.That is the idle screw.Turn it left to increase the speed.
Thank You for using Fix Ya.
Posted on Jun 04, 2011
kel1guy2002
  • 3740 Answers
SOURCE: I have a Briggs & Stratton 500 series push lawn
Hi and welcome to FixYa, I am Kelly.
When a primer bulb is slow to return to a static conditon there is a restriction in the fuel supply. Since this carb is mounted directly on top of the fuel tank the troubleshooting for this involves removing the gas tank and carb as an assembly from the engine. Remove the end bolt and then the side bolt spacer that is just above the tank. Be careful or the spacer will drop. Pull out on the tank until it slides off of the intake. When the tank is free of the engine tile the bottom of the tank toward you and disconnect the throttle linkage. NOTE the hole the linkage is connected to! Set the tank on a flat surface and remove the carb mounting screws. STOP! Do not lift the carb off of the tank until your sure that the gasket and diaphragm are not stuck to both mounting surfaces. You may have to carefuly slide a thin knife blade FLAT across the top of the tank to free the carb from the tank. There will be a SPRING on the bottom of the cabr also. Do not lose this spring and ensure you see how it is installed! Once the carb is free of the tank clean the screen under the carb and the carb with carb cleaner. Reassemble carb to tank. Fill tank with gas and re-check primer bulb BEFORE you reinstall the tank and carb on the engine. If it still does not work.. properly you need to clean the passages again. Worst case you remove the primber bulb to see if there is debris inside the bulb plunger area. Installing tank and carb to engine....
Tip the bottom of the tank toward you.. connect the throttle linkage, watch the o-ring that is in the carb intake sealing area and make sure it seals. Install side bolt and then the end bolt.
Just back tracking here.. I have determined this is most likely a 11A-B04E000 Yard machine with a 5.0 Hp engine... ( Briggs and Stratton refers to this engine as the 10T500 series.
ENGINE Parts list is here:
http://www.brandnewmowers.com/pdf/11A-104B090EIPL.pdf
Kelly
Posted on Jun 28, 2011
What is spark plug gap on unidentified pressure washer?
Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
What is the sprkplug gap for a 6.5 briggs &statton
Contact MTD if your manual doesn't cover this, or buy a shop manual. Or go to the Briggs & Stratton website.
May 20, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Briggs & stratton engine 500 series 158cc + spark plug gap
Look up your engine on the Briggs&Stratton website.They have all the specs. Or call MTD.
May 18, 2014 | Mtd 22" Yard Machine Push Mower
Where can I find a Briggs & Stratton 450 series 148cc magneto?
best place is from a B&S mower shop. Try e-bay as well as they are available on line. may be you know some one who has a mower that is not going that you can get the unit from it.
Jun 17, 2013 | Garden
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
What spark plug does my yard man lawn mower take? here are the numbers off the engine 110602-0131-e1
According to my data, you'll need a Briggs and Stratton Part No. 692051 for that machine. Cross reference to Champion Plug RC12YC. Note that this plug shows a recommended gap of only .020, as opposed to the .030, most Briggs plugs use. Best of luck to you.
Jun 29, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Aug 04, 2009 | Garden
Have Bolens series 080 22" mower w/Briggs & Stratton engine- starts but always quits after 2 minutes- changed oil, spark plug, and cleaned air filter.
Jun 14, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
1,219 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
