Question about Kitchen Ranges
Service manual for whirlpool ice maker AGB 022/01/G/WP
aborcass
  • 2651 Answers
SOURCE: whirlpool ice maker
this is a hard one to diag in person, let alone via email. you know your not getting water to the ice maker, problem is finding out why, ther is (or should be) a tech sheet behind the kickplate of this unit with a little trouble shooter and diag procedure for the ice maker. folded little blue/and or brown paper.
1. is the water line leading from the valve to the ice maker fill clogged/frozen??? pulll the machine out and youll see the line leadding to the top corner of freezer, disconnect that line and try to blow though to the insde of freezer, should blow withno resistance. if so your good if not youll need to thaw that line
2. is the red light blinking on the inside of door. its a sensor for the ice maker if its faulty you wont get ice either.With the flapper on rt wall of freezer depressed the light should remain on solid, if continues to blink a pattern, 1 and 1 quick blinks, 1 and them 2 quick blinks, youll need to replce the electronics
3. is the water valve itself just not sending water to the ice maker. its a dual vavle 1/2 does water and the other half feeds the ice maker . generallly youll hear the valve being energized, just no water coming through
4. ice maker itself can be damaged and not calling for water at all.a pretty common issue with these electonic control ice makers is the center gear actually over torques itself and winds up snapping itself(at least the tabs that hold ino place snap anyway). gaining acess to the face of the ice maker will tell this.
while looking at the exposed from\nt of ice maker you should see the center gear adn the 2 tabs holding the gear on as well. ther shoud be a SMALL but definite space betwwen the 2 tabs in middle of center gear, as if it were pressed on and the tabs spread back open to hold onto the gear. if 1 of the tabs is cracked or the gear isnot mounted correctly because of the tabs, you best bet is to replace the ice maker assy
GOOD LUCK
Posted on Mar 30, 2008
  • 1073 Answers
SOURCE: Ice Maker Won't Drop Ice
you have a problem in the module of the ice maker if it is new take it back for a new one
Posted on May 02, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Whirlpool Gold Ice maker doesn't work
You definitely have something wrong with the ice maker if the water has turned to ice Schmerold. And the IM is not harvesting. The way it works is the IM needs 28 degrees F to harvest. If the coils below in the condenser are dirty the IM won't try to harvest. The Ice Mold thermostat is mounted on the firewall of the Ice mold in its own little cubby whole. To access it you will need to remove the head. Then remove the shell separating the Ice mold from the heads housing. There you will find the ice mold thermostat. It's only function is to get it on. If the temperature is right in the freezer. To test this precious thermostat one needs only to stick it into a freezer and let it hang out for an hour or so. Then grab it and check it for continuity. If it is open it has failed and belongs in the file 13. It is easily replaced and inexpensive.
On your model, ice maker operation is controlled by an optical sensor mounted on both sides of the freezer liner. The usual failure of this model is a bad emitter board, located in one of these recesses. You may view the service instructions for checking this sensor.
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
I will also send free manual for you through email. And Rate my assistance.
http://servicepartstec.blogspot.com/
Posted on Apr 04, 2009
  • 351 Answers
SOURCE: Ice maker won't make ice on Whirlpool refrigerator
you most likely need to change the head of thie ice maker or just get a new one... very common
Posted on Jun 24, 2009
  • 185 Answers
SOURCE: water dispenser stopped working. Ice maker works.
Some of these ge frig have a problem with water freezing inside the door and so the water dispenser wont work. only way to be sure it to turn off your frig for about a week and leave the doors open. plug in then try the water dispenser. if this is the problem call g.e. you will need a special kit to solve this problem. it dispenser still doesn't work replace water valve!!!
Posted on Mar 22, 2010
How do I start the cycle on this ice2o ice maker? i have ice in the tray but the ice never dumps in the bin.
Go to page 19 in the Whirlpool Ice Maker Trouble Shooting Service Manual The manual should explain more than you will need on your Maytag/Whirlpool brand refrigerators. If you have questions please let me know, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
Ive just put a new grid cutter in my whirlpool ice maker but it is not heatinh up to cut the ice sheets into cubes. Any ideas what to do next?
Yes the next step is to check the voltage on the secondary side of the grid transformer found in the photo on page 30 of the=> 15 and 18 inch Whirlpool Ice Maker Service Manual
GI15NFLXS Grid Transformer
I hope the manual is a big help in resolving the ice cutting problem and please ask should you have any questions. The secondary side of the transformer should be showing a least 8.5 volts ac. Let me know if you are able to find the problem, Thanks Sea Breeze
The 18 inch ice maker takes the same grid transformer as the 15 inch model.
Mar 15, 2013 | Whirlpool Refrigerators
Whirlpool conquest model gd25dixht00 no ice or dispenser turning
This diagnostics are a little hard to explain in just a few short words so I am including a=> Whirlpool Ice Maker Electronic Eye Service Manual
4389102 Ice Level Control Board
This manual also shows how to test the auger motor in addition to the electronic eye. I will be here should you have questions Thanks Sea Breeze
Mar 14, 2013 | Whirlpool Refrigerators
My GE Monagram Ice maker is not making ice. I have cleaned with approved cleaner for the clean cycle and it does not seem to help. The water just seems to flow over the freeze plate and periodically a thin...
I don't have the service manual for this model without having to purchase one but I have a link to Whirlpool Service Manuals which is very much the same when it comes to diagnostics. There are several reasons that may cause this problem as you described. They are water control valve sticking causing warm water to continue to flow over freeze plate and stopping ice production. A defective condenser fan or a very dirty condenser coil. Link to Whirlpool 15 inch and 18 inch Ice Maker Service Manual Link to a site where there are information and answers for most model ice makers HERE You can contact this person at the bottom of the page, Thanks Sea Breeze
Mar 06, 2013 | GE Monogram ZDI15C Automatic Icemaker
Kenmore coldspot ice maker
What is your model number? Here is a link to the complete service manual for Whirlpool/Kenmore ice makers. You may need to create an account to access the service manual.
Sep 02, 2012 | 3M Refrigerators
Why is my ice maker filling up my ice tray with water then freezing it like a block of ice?
There are some adjustments that you can do if you carefully follow the instructions in the video below. I also have a Whirlpool Ice Maker Troubleshooting and Service Manual upon request. Your 67003753 Water Inlet Valve=> 67003753 Water Inlet Valve could be leaking and creating this block of ice. For most Whirlpool/Maytag brand ice makers is is cheaper to replace the core module part number=> D7824706Q Ice Maker Module. Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to do so, but I will be glad to send you one. The manual is the solution but the most complete module or replacing water valve is the cheapest route. Below is how it is explained a little simpler. If I can help you in any way please ask, Thanks, Sea Breeze
If helpful please rate this solution.
Jun 21, 2011 | Maytag MBF2256H Bottom Freezer...
How to repair an ice maker in whirlpool side by side refrigerator?
For most Whirlpool brand ice makers is is cheaper to replace the core module part number=> 2198597 Ice Maker Assembly Reason being the individual parts add up to more than the cost of all those parts together. Now if interested you can request a Whirlpool Ice Troubleshooting Service Manual by filling out the capsha=> HERE Reason I don't place the manual's here because Whirlpool ask me not to, but I will be glad to send you one. The manual is the solution but the most complete module is the cheapest route. Below is how it is explained a little simpler, Thanks, Sea Breeze
Jun 20, 2011 | Whirlpool ED5FTGX Side by Side...
Will not make ice
The ice maker has completely stopped producing ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Whirlpool GS6NBEXR Side by Side...
WP side-side freezer appears to be overflowing the
You just need a new water valve for this unit. Call us with your midel number and we'll be sure to get the right part out to you right away! We look forward to hearing from you soon.
Oct 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Ranges Logo
148 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
