Question about Frigidaire Washing Machines
Front loader, frigidare, not draining properly.
  • 122 Answers
Your washer has a drain catch, a small plastic cylinder with holes in it, that catches things left in you clothes. It may be restricted. You may have to clean your drain catch. It is located inside the hose that comes off the bottom of your outer tub, at the bottom, and goes to the drain pump. The easiest way to do this is to pull unit out enough to where you can tilt it back to rest against the wall. At the bottom of the washer there will be an oval shaped hole. You can access the hose with the drain catch inside of it. Remove the clamp at the tub with a phillips screwdriver or a 9/32 or 7mm socket. Before you do this you may want to remove any water still inside tube with a shop vac attatched to the washer drain line. If not alot of water will come out on the floor, or just get some towels, it will be messy. Once you have removed the clamp, remove hose enough to where you can pull out plastic cylinder inside hose. Make sure when you reinstall hose, that the hose is pushed up all the way against the tub, all the way around, or it will leak. Good luck!
Posted on Aug 28, 2010
5 Suggested Answers
  • 6 Answers
SOURCE: Frigidare Gallery 2 speed top loader fills with
It could be multiple problems, if so it's more than one of the below, it would be cheaper to buy a new unit.
Start by removing the front panel and check the belt and idler pulley/tensioner. Look for wear in both and make sure there isn't too much play (it should only move about a 1/2 inch when pushed on it's longest stretch. While you have the front open, inspect the pulley for damage or excessive play.
Another cause could be the transmission (it's just above the pulley). Look for fluid/oil leaks and/or rust. A bad oil leak can cause the transmission to seize up. If you notice rust accumulated on the transmission assembly, you probably have a bad seal. Water could have gotten in there causing it to fail. A damaged transmission needs to be replaced, repair parts are not available.
The cycling problem sounds like a faulty timer. Test it by advancing the dial and make sure the correct cycles are starting/stopping. This part can be replaced with a few simple tools.
As always, make sure you disconnect the power before doing any service.
Posted on Sep 19, 2009
rylee_smith
  • 8619 Answers
SOURCE: front loader doesn't drain properly, water lwft in
Hi
Thanks for using FixYa. If your washer won't drain, check these:
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Dec 05, 2009
  • 89 Answers
SOURCE: my whirlpool front loader washering machine is not
Hi, What I would like you to do is go to the drain filter at the bottom of the machine. You may have to remove the kickplate. Its held in place with 3 star screws. Next get a shallow cake pan, and put it under filter handle. Slowly turn counterclockwise until water starts coming out. Let is drain til about half full and empty. Keep doing this until no more water comes out, then unscrew all the way counterclockwise and pull out and remove and clean. Reinstall filter and kick plate. Hope this helps and have a good evening.
Posted on Feb 24, 2011
  • 6277 Answers
SOURCE: I have a frigidare Affinity
Could be something is jamming against the drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 01, 2011
Frigidare gltf1670as
You likely have a broken or slipped drive belt or broken spring on the belt take up arm on the drum. Appliance Parts.com has a lot of DIY instructions on how to get at the belt and make repairs.
Jan 23, 2018 | Washing Machines
Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Sep 30, 2009 | Samsung Washing Machines
Aug 02, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
My washer is showing a code
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water if you have water
  3. Can be caused by bad pressure switch
  4. Can also be caused by clogged pump
  5. also by too low of a drain hose height.
    Check for clean filters of the inlet water line.
    Check that the drain hose was assembled as per the manual's instructions.
May 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
Loud banging on spin cycle frigidare washing machine model no. fws235rft2
If this is a front loader this is a common problem. Unfortunately, it is also a very extensive project (about 8 hours). The tripod supports that attache the drum to the center spindle commonly break. The remedy is to replace both the front and rear tub, and the basket as well. It is also recommended that you replace the drain pump as well. Generally, they will cover the parts (not including the drain pump) under warranty but the labor will be a customer pay.
Oct 19, 2008 | Frigidaire Washing Machines
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Frigidare Front Loader Won't Spin on Certain Cycles
part of the problem sounds like you still have a blockage check all hose's to pump....also if drain hose is connected to back of machine check connection there. common for lint or objects in these areas. most common coins get lodged there and act like a valve. Not sure bout your cycle selection...check your options are set correctly?
Nov 07, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
