Question about Whirlpool Dehumidifiers
We recently purchased a used Whirlpool Gold Accudry 50 pt dehumidifier for use in our basement. Model: AS50USR1, Seriel # QS2979612. Ever since we plugged it in, it has been running constantly and making the room quite warm. I have to empty the water collected several times a day, so it is doing it's job. However, the heat output concerned me. So, I looked online and saw that quite a few Whirlpool dehumidifiers that look the same and with almost the same seriel numbers (Q....) had been recalled for problems with overheating and fires. QS is not one of these numbers, but because it looks the same, I am concerned. I don't know anything about this unit and don't have access to a manual. Since it has not shut off, I don't know if it's humidistat is working properly. The basement walls, rugs, etc. could have quite a bit of moisture in them, which will take a while to remove and could explain why it never shuts off. This unit does collect the humidity o.k., but the heat it produces in the room concerns me. When you buy a used appliance, you're never sure if it's running properly. What do you think?
  • bnlabel Aug 28, 2010
    The Whirlpool Gold dehumidifiers claim to be low heat producers, but this one heats up the whole basement. Are you sure it is performing properly - espeically that there is no danger of fire, as was true of other recalled Whirlpool dehumidifiers with similar seriel numbers?
  • 864 Answers
If the entire unit is getting severely hot then yes i would be concerned as well. Give whirlpool a call and ask them what is the operating temperature range. Im sure they would be glad to assist you or even tell you if you have one of the units that may be defective. If its not hot to the touch i wouldnt be to concerned though. As these units do get warm, but the entire unit shouldnt be burning warm. An from what im finding online these units really shouldnt be getting hot enough to heat your entire basement. Since the recall specifies units with Q i think this may be a unit under the recall. But there is only one way to know and that is to all whirpool specifically. If you need further assistance i will be glad to assist you. Just follow up with a comment and i will be glad to assist you further. Thanks, Midwest-tek
Posted on Aug 28, 2010
  • 787 Answers
Personally, I think you're OK. The heat output is normal ... only when you will notice excessive heat output you should consider replaing the unit with another one.
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Fan works but compressor does not kick in, therefore does not collect water. temperature and humidity in basement : same as before
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Apr 15, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumifier blows out my electrical switch in my electrical panel.
You definitely have an electrical short in the unit and should stop using immediately. Have it checked out by a licensed electrician. It is a very real fire hazzard.
Jun 07, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
When do you use the dehumidifier?
In areas with poor circulation and humidity over 80%.
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
My Whirlpool Gold dehumidifier is making the circuit breaker switch off. I used the sweeper to clean all of the dust from the vents but it continues to make the breaker switch off.
Take the unit outside and wash the coil out with a garden hose. Careful not to get water on the controls. Water will not hurt the motor or compressor as long as you keep it unplugged. Allow the unit to completely dry before running it again.
Oct 04, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Brand New De-Humidifier not pulling water into bucket or hose !
I have lost my manuel. I do not know how to use the hose for when I go away for a few days.
Apr 28, 2009 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiers Logo
99 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
