Question about Epson Stylus RX500 All-In-One InkJet Printer
Scanning on rx 500
Tried uninstalling and re-installing drivers computer will not recognise scanner please help
Are you using Vista ? You have to download the new drivers from Epson here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26321&infoType=Downloads
Posted on Jul 05, 2008
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
My scanner was scan docs to my computer now it says No scan options. whats up with that. its a hp all in one j4680. please help!
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question or eclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot hope this helps
Jul 12, 2011 | Computers & Internet
My Canon PIXIMA 510 printer won't scan because the ink is out. I really need to scan something! What should I do?
this should scan without any ink
the drivers for the?scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
Jun 08, 2011 | Computers & Internet
As I want to scan a paper, scanner does not work properly. I tried many times but the scanner cut the paper from diffent areas as I tried over and over for several times. I got the exact scan maybe ten...
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
hope this helps
May 02, 2011 | Computers & Internet
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Jul 31, 2009 | Syscan TravelScan 662
Im trying to scan an image into my computer... but the printer is saying that its not connected... It is connected because I can print to it just fine...please help!
chk for the scanner drivers in the control panel..try uninstall and reinstalling them if you see them...then try scanning from the computer first to see if the drivers are installed.if it works make sure you have the s/w properly installed to scan to the computer..
Jun 24, 2009 | HP Office Equipment & Supplies
Scanned image is blank, although the page inside the scanner has text &/or picture.
Scanner contains Unlock botton below it, just unlock it it will scan fine.
Vikrant
May 08, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
It does not work. The computer dos not recognise it
Hi Sir,
I have Acer Scan Prisa 640C Flatbed Scanner ,which is having parallel port. When I installed the driver ,start to scan ,the computer does not recognise the port ( Parallel Port ).
So please help to solve this problem step by step instruction.
My operating system is Windows XP Professional.
Computer is Intel P 4 --3000
Hdd 80 GB
DDR 512
Thank you.
Jun 01, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Problem to see any document on my scanner
Is the scanner not recognised or is it Not scanning?
Is the comp recognising the scanner? If not reinstall the driver. Run scandisk on the drive where the OS is installed. Try uninstall and reinstall.
Pls check if the scanner platten is moving, it could be a hardware problem.
Feb 21, 2008 | Office Equipment & Supplies
Epson Stylus RX500 All-In-One InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
