Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
When i pull out hose it immediately will **** inwards together and I it is hard to move and has litten suction.
  • 694 Answers
Sounds like a clogged hose. Try to roll a marble or small rock through hose. If it doesn't go through, it's clogged. If you've got a shop or canister vacuum, try hooking your hose to the exhaust port of other vacuum. Detach your hose from your vacuum first. Turn on other vacuum, attempting to blow out or dislodge clog. You can also try using an air pressure hose, or getting a long length of PVC pipe, to help clear it. Do not use sharp/pointed objects.
If the marble rolls through, check the flex hose inside the power head, This may be clogged and need to be unplugged. If it can't be unclogged without damaging it, it will need to be replaced.
Posted on Aug 29, 2010
Dyson DC14 hose won't extend and floor unit lost suction
Sounds like the exhaust side is clogged. Remember a vacuum pulls air into the cavity, but for it to work properly it also has to be able to exhaust the same amount of air it takes in. If the exhaust is blocked it will continue to suck air inside and collapse on itself, which is why your hoses are getting shorter and harder to move. Check the exhaust system for any blockages, perhaps the hole you taped was the exhaust.
Mar 15, 2015 | Dyson Vacuums
Losing sucksion
If you look underneath your DC07 you will see a short length of clear plastic hose with spiral wire reinforcement. Quite often this hose splits (which lets in air and reduces suction at the brush head). Check this hose carefully, as a split is not always immediately obvious. If necessary, remove it by just pulling it away from the end nearest the motor and then unscrewing it from the brush end. A new hose costs very little so it's hardly worth trying to seal a split with tape.
If this is not the problem, post a reply and I'll try again. Good luck!
Jan 15, 2010 | Dyson DC07 All Floors Bagless Upright...
Dyson Animal
Obstruction in the hose?
Your vac has developed a hairball possibly.... when a piece of flexible media ie.... cardboard, plastic etc... gets lodged in the hose, and begins collecting hair & dust to the point it no longer has enough draft to pull debris from the floor.
Here is a video that you may find useful
http://video.aol.com/video-detail/dyson-not-picking-up-dirt-no-suction-how-to-repair/2334249387
PS I Thought DYSONS were guranteed to NOT lose suction? What a RIP!
Jan 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
It has been cleaned , yet there is no suction the hoover wont pick hardly anything up & it gets hot very quickly
Then there most be a clog either in the hose or the dirt inlet by the brush roll. If you pull the hose off like you are going to use an attachment, is there suction there. If not, then the problem is in the hose. If there is suction, then the problem is down below,
Jun 14, 2008 | Hoover Vacuums
Vacuum doesn't suck (boy, what a problem :D!)
First, check the suction at the end of the hose and make sure there is good pull. On some models, there is a filter tray located under the dirt cup with a washable foam filter in it that could be plugged. It is also possible that the tray could have fallen out during your move. If it is missing, the motor will run, but won't direct the suction to the cup and you won't get any suction from the hose. Note.. not all models have this tray. If the tray is missing, you shouldn't get any suction from the hose.
Jan 13, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
I lost the manual to my vacuum
Hi.
If no suction from hose check the following.
The (U) shaped inspection port at the back of machine where flexi hose enters has not come off or has a blockage.
Remove flexi hose from rear of machine once off slide it fully up the wand handle hold handle end up to a light & look up the pipe for blockages.
Check side premotor filter.
Does it pick up ok when using to vacuum carpets or is that got bad suction to ?
http://dc07.atspace.com/
Chris.
Nov 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vaccum has no suction
Need a new belt -- you might have suction but you need the brush to spin (hard to help without make or model, upright or canister)
Oct 17, 2007 | Kenmore 25614 / 25615 Progressive Bagged...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
64 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
