Question about Dell Inspiron 530 Desktop Computer
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just started happening.
    Scholar:
  • 166 Answers
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Posted on Aug 29, 2010
Floppy diskette seek failure strike the F1 key to
it's not a major problem.go to bios screen by pressing F2 and DEL in keyboard at startup you will enter bios screen there you can change the boot device properties.change the first device to hard disk and second to CD or DVD ROM drive.it will solve your problem
Aug 29, 2014 | Computers & Internet
Floppy diskette seek failure during start-up
You can disable that by changing the boot sequence of your computer.
Turn on or restart your computer and watch for a message while your computer is restarting about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
You will a screen where it says BIOS Setup. Use the arrow keys to navigate to it and look for the option that says Boot Sequence or Change Boot Sequence. Each computer differs so I can't tell you the exact appearance of your computer's Bios Setup.
You can find the instructions on how to navigate in Bios by looking at the bottom part of the screen.
Change the boot order from there. Make your main hard drive as number one and the floppy drive in the last. You can see the instructions on how to do that in the screen in BIOS setup.
After changing the order. Save and Exit. It will restart automatically and observe if you still see the issue.
I hope this helps!
Please let me know if you need more assistance.
Carlo
Jan 26, 2013 | Dell Computers & Internet
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
Black screen with Diskette drive 0 seek failure on it. pressf1 to continue, f2 to enter setup
diskette drive o or disk drive o? f2 to enter bios check boot options to boot on drive o [hdd-0], most boot options go floppy,cd-rom, hdd-0
Feb 04, 2010 | Dell Inspiron 530s Desktop Computer
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Diskette driv 0 seek failure
press f2 go to the boot priority and select harddrive to the first boot.
Nov 22, 2008 | Dell Dimension C521 PC Desktop
Drive 0 Seek Failure
Do you have a floppy drive on this computer, If so this message means that the drive is bad.
If you want to disable the message or you do not have a floppy drive, do the following:
Go into CMOS setup by hitting F2 key while the unit is booting up, scroll down to disk drives on the page, there you can disable the Floppy drive. Hit ESC and reboot.
Good luck,
Joe
Please remember to rate Techs who assist you for free :)
Oct 09, 2008 | Computers & Internet
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Dell Inspiron 530 Desktop Computer   Logo
324 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
