Question about Whirlpool LER5636P Electric Dryer
We have a Whirlpool Dryer Model LER5636JQO. After drying numerous loads after a camping trip, the heating function quit. The dryer still spins and the blower still works. I should also note that I checked the fuse panel and it was not tripped nor any nearby gfi outlets. Obviously, I'm no expert but is there a simple internal fuse(s) I could replace or do you think it is a heating element? Thanks in advance for your help. - John
    President:
  • 1,218 Answers
Good day,
could be either.
Remove the back panel. On the right side is a cannister that holds the heating element. You will need a VOM meter to test it. There are 2 terminals sticking out the bottom of the cannister.
Remove one wire and check accross the 2 terminals. The reading should be less than 35 ohms . If it reads infinity, it is burned out and needs. replaced.
The other item is the fuse also located in the same area near the center bottom. It should check zero ohms. If not, it will need replaced.. It looks like this.
Here is a link on changing the element if needed.
As well, there are other safety thermostats located in this same area. They should be checked. All should read zero ohms.
http://www.applianceaid.com/wp_element.html
Posted on Aug 28, 2010
I have a whirlpool electric dryer.. when I turn it on its been having a problem with staying on or not heating at all. It will spin and stay on but no heat.we have changed the element and it seemed fi
Sounds like a tripped circuit breaker in the power panel for the house. The breaker for the dryer is actually 2 breakers connected together so if one trips so will the other. Sometimes this does not happen and only one breaker trips. This condition removes power to the heating element but still supplies power to the rest of the dryer. Check to see if the breaker will reset by turning off and back on several times. Then check the power receptacle that the dryer plugs into with a voltmeter set to read 240 volts AC. If no 240 but 115 is present then replace the circuit breaker.
Nov 19, 2014 | Whirlpool Dryers
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool AWZ410 Washer/Dryer Washes But Will Not Dry!
I have the same problem. The half load / drying button is pushed in; the drying time set; I've reduced the load to almost nothing, but it won't dry. I've tried numerous cycles. The clothes spin, but are still damp at the end.
How would I go about checking my lid switch or fixing my clutch, if that's the problem?
Sep 04, 2009 | Whirlpool AWZ410 Front Load Washer/Dryer
Whirlpool Imperial Electric Dryer wont heat up
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 22, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer heats but quit spinning
Your belt has come off or has broken. Do you hear the motor running? If so, then the belt is broke or off.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Whirlpool dryer, LER5636JQO, long drying time
Not always the case, as there are at least 2 thermostats that could cause the prob, if it is getting hot, then perhaps only part of the element is heating, also make sure u have high heat selected.
U really need to access the heater and stats to check them.
Plz rate this solution.
Thanks.
Jan 01, 2009 | Whirlpool LEB6200 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
101 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
