Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool Duet HT. Moved it to clean behind it and now control panel won't work. It has power because when I plug it in the light that says contro panel locked is on. Nothing else works and the screen is blank. Any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this and unlock the controls you’ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Control locked light is on my Whirlpool duet ht washing machine. What can cause it?
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 11, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Unresponsive control panel- Whirlpool duet dryer 4 years old
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water leak from my washer underneath i have a Whirlpool Duet Sport® HT 3.7 I.E.C. cu
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on, how do I reset the machine?
Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
Mine just did the exact same thing. I unplugged it, then plugged it back in, and it worked perfectly. Good luck!
Dec 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
