Question about TurboChef TORNADO Electric Oven
F8 heat low it goes up to 494 and stops there
    Scholar:
  • 75 Answers
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Posted on Nov 01, 2010
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
F8 code; IR element will not heat up
If you are getting convection heat. I would say it is a bad IR element. Visually inspect the IR element. Sometimes the wires going into the side will be burned and broken. You could also check continuity going through the IR element or ohm it out.
It is rare for those relays not to provide heat. Ive had a bunch stick on. Put anything is possible.
Mar 05, 2013 | TurboChef TORNADO Electric Oven
My oven door is locked closed. Also, it reads F8 and beeps. In order to stop the beeping, the cancel/off button must be hit. When I do that, the fan turns on for about a minute and then stops and goes back...
The control board runs self checks about every 10 seconds to check the oven codition,and what the F8 error code means is it has detected a problem with the control board itself and it needs to be repalced
Gene
Aug 04, 2011 | Jenn-Air JJW8430D Electric Double Oven
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
Problems with TurboChef TORNADO Electric Oven f8 erro.
F8 means Heat rise low the oven failed to warm up in a predetermined time period. First check for problems with the blower and then check the high limit thermostat to see if its tripped. If these are okay call a repair tech because you will need to check the relays for problems
Jan 21, 2010 | TurboChef TORNADO Electric Oven
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Nov 15, 2008 | TurboChef TORNADO Electric Oven
Jennair single oven...
Hey marygilfilen
F8 error is associated system failure. I suggest you need to replace your clock (controller)
Regards
Aug 19, 2008 | Jenn-Air JJW8130D Electric Single Oven
Kenmore model # 911-494-79790
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
May 11, 2008 | Kenmore 30169 Electric Single Oven
TurboChef TORNADO Electric Oven Logo
260 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
