Question about GE Refrigerators
Sidex side 26 cf... 5 yrs old... frequent water on floor under freezer... freezer temp is erratic and will seldom be below 6, but infrequently will go below 0 setting ..can not keep ice cream
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
Kenmore fridge, 7 yrs old, freezer on top. Water sprays periodically from somewhere at top inside of refrigerator, apparently from downward pointing chute or holes on either side. This seems to be part of...
Removed inside rear and floor panels of freezer (ice machine also) as ably advised by your tech. Found ice damming he suspected underneath floor panel. Thawed overnight with pot of hot water in freezer. could see that small rear drain tube was iced shut; why all water going into fridge below. Avoided floor mess from thawing water flow to evaporation pan on floor by tilting unit forward on blocks and laying several old towels inside freezer door to catch water that would run out. Also placed some in front at base of unit on kitchen floor. Continuing to thaw pipe to unclog, it is iced some way down, again as tech said it might. Will reassemble and be careful with freezer setting, in case it may have been too cold. Also, some food crumbs had found their way behind panel near this drain tube and may have fallen in to block it. Will clean out any remaining.
Jan 05, 2010 | Kenmore Refrigerators
I have a side by side Whirlpool refrigerator. It is about 6 yrs old. It has recently started having ice build on the floor of the freezer. Any idea for a fix on this problem?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
39 ltr engle fridge freezer wont shut off when at temp
hi,
the temp should be around 35-40 in the fresh side and below freezing in the freezer. If the probe is positioned wrong then it may not shut off. Does the probe need to be in the freezer compartment?If the freon level is wrong then the freezer may not get cold enough to shut down the control tstat. The low side pressure should be around 5 PSI.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Refrigerator leaking water on floor under it!
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
Jun 18, 2009 | Maytag MSD2656G Side by Side Refrigerator
Same as 6-9-08 freezer ices up, frig won't cool
Not sure if this will help but I have/had a similar problem with my admiral side by side (approx 12 yrs old not sure of the model #)and I think I fixed it this morning..
At the back of the fridge compartment I removed the cover (covers the light and controls) the Freezer setting just seems to adjust a flap that sends cold air into the fridge.. around the flap was a mass of ice.. what seemed to be happening was as this 'vent' was blocked with ice no cold air entered the fridge and the temp stayed high and hence the stat did not cut out .. compressor running flat out 24/7..... I removed the ice and it now seems to be working better (2-3 hrs will see what its like when I get home from work..!)
Jul 09, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
