Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
Hi, I just bought a Delonghi Magnifica 3300. I am not able to start it. All the bottom row lights keep on flashing and I can't get past this point. Any ideas?
  • 2 more comments
  • georgimitrev Aug 29, 2010
    Definitely! I went carefully through all the instructions and key combinations on the front panel of the machine, I even went on the Italian Delonghi website (as I happen to know this language) and studied the instructions in this and a few other languages, comparing the evolution from one model to another... This yielded no result at all!
    My doubt is the electronics are corrupt or there is some mechanical issue with the infusor/front door of the machine, disallowing me to bypass this stage and move on to complete use.
    Do please try harder, as I wouldn't have gone to paying 6 bucks just to be cleverly asked whether I connected the machine :-)))
    Solution 1
    valeantudor
    ? Rank: Guru
    ? Rating: 86.55%, 166 votes
    Are you sure that it is properly connected?
    o georgimitrev
    o posted now
    Definitely! I went carefully through all the instructions and key combinations on the front panel of the machine, I even went on the Italian Delonghi website (as I happen to know this language) and studied the instructions in this and a few other languages, comparing the evolution from one model to another... This yielded no result at all! My doubt is the electronics are corrupt or there is some mechanical issue with the infusor/front door of the machine, disallowing me to bypass this stage and move on to complete use. Do please try harder, as I wouldn't have gone to paying 6 bucks just to be cleverly asked whether I connected the machine :-)))
  • Nicole Sep 30, 2011
    The flights are flashing please help! Can't get past this point
    The lights are red going thru all the symbols
  • 4,924 Answers
I will take them one by one and what it means ..
first when the 3rd light is red and flashing (the one with the triangle sign ...it means that you have to close the service door..
the one in the middle means that it something wrong with the used coffee container..and when it is lit these are the actions to be done ..
•Check the used coffee container by removing it. If it is full, empty the
container, clean it and replace
the container.
•Check to make sure the used coffee container is in the machine. If it is missing, replace the container.
•Check to make sure the used coffee container is properly positioned. If it is not properly positioned, reposition the container until it fits correctly inside the machine.
the first light in the left it is the water container light ..and when it is lit you have to follow these actions ..
•Check the water tank by removing it. If it is empty, refill the tank with water and replace it.
•Check to make sure the water tank is in the machine. If it is missing,
replace the tank.
•Check to make sure the water tank is properly positioned. If it is not properly positioned, reposition the tank until it fits correctly inside the machine.
when they all flash it usually means that when you cleaned it or ..dismount it and put it back ..you left the brewing system out of the machine or it is not inserted proper..so ...the acvtion is ..
Leave the service door closed and the brewing system out of the machine. Press the 1-cup and 2-cup buttons
simultaneously until the four lights go off. Only when all of the four lights are off can the service door be re-opened and the brewing system replaced.
Posted on Aug 29, 2010
  • 787 Answers
Posted on Aug 28, 2010
Squeaking delonghi magnifica
Take it apart and clean it properly plug use sileco to lubricate for a longer use water heat coffee all of these make machine to fail
Keep service as importance
Jul 09, 2014 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica 3300 doesn't make coffee, only wet grounds and water in the grounds container, everything else seems normal
Hi JB, not sure if you've junked your 3300 machine by now or had the problem fixed already. Nevertheless, allow me to share with owners of DeLonghi Magnifica Espresso machines who encounter similar problem to yours. Incidentally, mine is a Delonghi Magnifica 3200 which is very much the same as the 3300. Firstly, try to ascertain if the pump is working normally. When the machine is ready to brew coffee, turn ON the steam/hot water knob and see if it pumps normally and for more than 30secs at least. My machine could pump for short durations between 5secs to 20secs max before the water light came on. I checked the flow meter connection but is all seemed well. I noticed signs of water leak (dried up chalky water stains) where the steam wand exits the control panel. Upon opening up the control panel, I noticed a larger patch of dried up water stains on the wand valve assembly. Bought a set of steam wand assembly replacement and to replace the leaking one. It's been some six month now and I'm enjoying my daily cuppa again. Btw, my Delonghi Magnifica 3200 has been serving me well for 10 years! Apart from the steam wand replacement and a faulty micro-switch, I only had to carry out the usual descaling and replacing worn out O-rings.
Feb 10, 2013 | DeLonghi Magnifica 3300 Espresso Machine
There is a red light flashing thru all the icons underneath the controls
Run the hot water tap until the lights stop blinking. It is asking for the water circuit to be primed IIRC.
Sep 30, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Why doesn't my descaler light ever go off from flashing?
Perform the full descaling program as described in the manual to reset the descaling counter.
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
171 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
