Question about Polaroid FLM-3732 Television
Control Box Hi Kvmann77, I receive mine yesterday night, I put it on and works. I was lucky probably. It didn't look new, there was a little dent on a corner, but I tired it anyway. Now everything seams to be working, but before I sent the old one back to them I will wait at least few weeks to see if this new one hold up. Thank you for your help and insight.
Well I received my control box today and no luck. I had it installed and still no picture or sound, but at least now the tv turns on and off....lol. Fired off another email to the rep at Polaroid asking for a new one and will see how it goes.
Posted on Jun 03, 2008
  • 4 Answers
Hey buyer74,
That's awesome!!! Congratulations on your TV recovery...lol. I would definitely hold onto your old one just to be sure.
I guess Polaroid isn't all that bad. Their customer service just saved you and me $300-$400. I still won't buy another Polaroid though...lol.
Take care and good luck in your TV adventures..
Posted on May 07, 2008
Dashboard not working
Its probably the binical its self dash board that is you can check the fuses in the fuse box first though also you can take the binical out or pull it forward to make sure the scart lead type conector hasent come lose or you can take the lower panel out from under the steering wheel and put your hand up the back and have a feel there are 2 1 each side hope thus helps cheers ivan
Nov 20, 2017 | 1997 Mercedes-Benz C-Class
Tip
Air conditionor randomly kicking off and blowing hot air, fixed!
I bought this car from my mother, and she constantly had the problem of the A/C just kicking off with a high-pitched buzz and suddenly it would blow hot air!  She replaced the entire AC system (lucky me!) and gave up on it.  I fixed it with a $5 junkyard part... The HVAC control module (the interior button control).
You must disassemble the dash by first pulling off the lower covers (mine were wood-toned) then unscrewing all the pieces holding the dash cover in place.  The one in the glove box was the biggest pain!  Then 2 little screws hold in the HVAC controller.  Pop it out, plug in the new one, screw it in.  I also put in a new stereo while I was digging around, using a cheap stereo install kit.  It also left room for a little shelf (included in the kit) to put the remote into.  I put a little piece of rubbery grip stuff in it so the remote won't slide out.
I am not a car person, and it was a fairly easy (but long) repair.  It took me about 2 hours to get the dash pulled apart, then another 2 to get it all screwed back in.
on Mar 26, 2009 | 1995 Buick Park Avenue
Transmission problem with 97 camry
The 97 has an allen head(14mm?) drain plug on the pan. Drain the fluid and
exaimine it in a clear container. Good transmission fluid smells like new ATF and is usually red. If yours is dark and smells burnt AND/OR HAS DEBRIS IN IT which I think is likely, you will need a new ******.
Dec 20, 2011 | 1997 Toyota Camry
Remote no longer powers off or on the reciever, nor does it control any of the recievers functions, however it does work the TV & Cable box. I just purchased a new universal remote, it controls...
If you have tried the reset of the receiver in the owners manual (Holding the Power/Standby switch while simultaneously plugging the receiver power cord in the wall outlet) and that doesn't fix the problem then you are probably discovering that the receiver has a welding problem with the IR sensor pins to the circuit board. Go to this website http://mysite.verizon.net/amp68/ to find the 3 pins that need to be welded. I just did this last night and it works. You can count me as one 5 people that have had success with this fix.
Jun 01, 2010 | Kenwood VR-507 Receiver
Hi box super went last night have no channels has any1 got any codes for northeast area thanks a lot
hi. my starview box stopped working 2 days ago.
can anyone HELP
new codes please
25-08-2010
zaks
Feb 23, 2010 | StarTech.com StarView SV211K 2-port KVM...
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
2003 Honda Accord Ex - navigation stopped functioning
Hi, it could be that the screen is in the off position, press daylight/night button twice. From what I've read in other forums pressing that button twice turns the sat nav screen off. Buying an updated DVD will not solve the problem. you can also try a dvd cleaner.
Your lucky if your progress bar has fully loaded up. Mine hung up with about 2% and will not respond in any way now, I have to send it away to Alpine for fixing. Hope this helps
Jul 09, 2009 | 2003 Honda Accord
Dents
Look at the door, is there a bunch of screws holding the magnetic gasket on? They probably hold the whole plastic inside part on, too. If you are real lucky, the insulation inside will come out easy. If it has been sprayed or poured in, you can't get to the metal to pound it flat from the inside out. For that you would need a bunch of groovy car body working tools. It would take all day,,and what are you going to do with the food, a cooler? How about hiding the dents with decor objects, I'm not sure refrigerator magnets will stick. P.S. If you do take the gasket off, tighten the screws only a little while checking the door fit. Once you know it is flat, you can snug them up.
Apr 28, 2009 | Refrigerators
Set to box problem
Where did you grab the firmware for it? I can't find it anywhere!
Aug 30, 2008 | Teac Audio Players & Recorders
Does not power on
you probably blew a fuse in the power supply
Feb 07, 2008 | Yamaha RX-V661 Receiver
Televison & Video Logo
41 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
