Question about Sony Alpha DSLR-A100 Digital Camera
My sister has a Sony Alpha DSLR-A100 camera. She says that when turning the camera on and shutting it off, it makes a whirring-grinding-propeller like sound. for a while. She purchased a news lens, thinking that might be the problem. THht seemed to correct the problem temporarily, but it is doing the same thing again. Any ideas what might be the problem?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Does the error happen each and every time you take a snapshot, or only with some? As you are letting us know, have a look around the user manual to see if it can be of any help:
Sony a100 wont turn on
If the battery is charged, try replacing the battery first. Also try turning on the camera with the charger plugged in. If neither helps, you will probably need to have the camera sent for repairs, but you can still try checking out the user manual for helpful information:
Nov 11, 2013 | Sony Alpha DSLR-A100 Digital Camera
Take apart sony alpha a100
Before attempting to take the camera apart, make sure to refer to the user manual. It will contain diagrams and schematics for the device:
Jan 05, 2012 | Sony Alpha DSLR-A100 Digital Camera
Image shifts off center and two corners appear rounded as if you are focusing on the rim of the lens.
Image shifts off center and two corners appear Problem with the Sony Alpha DSLR-A100 Digital Camera That
The Sony A200 kit (DSLR-A200K) comes with a DT 18-70mm (3.9x) f/3.5-5.6 zoom lens for an estimated US$600.
A separate Sony A200 kit (DSLR-A200W) includes two lenses: the DT 18-70mm mentioned above, and a 75-300mm f/4.6-5.6 telephoto zoom for an estimated US$800.
Click Here To Watch More Information about This Answer
Jul 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
Alpha DSLR-A100 Digital Camera: i got problem with memory card. keep showing the m...
not all memory cards fit sony alpha perhaps you have bought wrong cd.try using your sd slot
May 06, 2010 | Sony Alpha DSLR-A100 Digital Camera
Sony DSLR-A100, error code 0x5b
Same here. My camera gives me the same error code unless I shoot with the largest aperture/smallest F-number.
Mar 28, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 does not turn on anymore
Opening the device might help, check the connector of the battery if still connected. The drop may cause lose connections, may also happen to have a crack board... ^_^
Jan 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
138 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
