Question about Logitech 9313960403 Mouse
Mouse has a reset button on the bottom the software downloaded there are brand new batteries in it the pointer will not move. This mouse has worked with this laptop before what is wrong with it?
  • 787 Answers
Press the Reset button on the receiver also.
Posted on Aug 28, 2010
How to make a optical mouse work better?
Your mouse is an important part of your computer system, and when that mouse has problems it is important to get them resolved as quickly as possible.
There are a number of things that can cause a mouse pointer to behave erratically, and it is important to work through each of those possible causes one by one.
Change the batteries if you are using a wireless mouse.
The batteries in a wireless mouse will generally last a long time, especially if you use rechargeable batteries.
But once the battery power begins to decline, the batteries will lose power very rapidly.
If you are using a wireless mouse and the cursor begins to stutter and jump, chances are that changing the batteries will resolve the issue.
Move the wireless transmitter to another USB port.
Problems with the wireless transmitter can cause the mouse pointer to stutter and jump. Moving the transmitter to another port will often resolve this issue.
Right-click on the "My Computer" icon on your computer's desktop, and choose "Properties" from the menu.
Click on the "Hardware" tab, and click the "Device Manager" button.
Navigate to the mouse entry in the list of hardware devices, right-click and choose "Update Driver" from the menu.
Allow your operating system to search for and install the most recent driver for your model mouse.
Clean the mouse surface thoroughly if you are not using a mouse pad.
If you are using a mouse pad, shake any dust or dirt off of it to make sure the surface is perfectly smooth.
Any imperfections in the surface could cause the mouse pointer to behave erratically.
To clean the mouse surface, hold a clean cloth over the opening of a bottle of isopropyl alcohol and soak the cloth.
Then, go over the entire surface with the alcohol-soaked cloth and allow the surface to dry before attempting to use the mouse again.
Click on the "Start" button, and choose "Control Panel" from the menu.
Double-click the "Mouse" icon, and click the "Mouse Pointer" tab.
Adjust the speed of the mouse.
If the mouse speed is set too fast, it can cause the mouse pointer to stutter or hiccup.
It may take a few tries to get the speed just right, so just move the slider and test each new setting
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Hope this helps
Nov 04, 2012 | Computers & Internet
The mouse and connector in the USB are lighting up and the mouse wheel and buttons work but the pointer will not move.
try to push and hold the synchronize button (or connect button) on bottom of mouse. Also make sure that batteries are new.
Oct 04, 2010 | Microsoft Wireless Mobile Mouse 3000
Mouse does not move cursor. Has new batteries.
Hello
There is a small reset button on the bottom of the mouse push and hold it in for a couple seconds.
You would need to download and install software and drivers for mouse from the manufacturer to get a battery saving option.
Mar 21, 2010 | Logitech Cordless Mouse
The mouse does not work
Change the batteries. If still a problem, try the mouse on another workstation. If it still doesn't work, it will confirm that the mouse or USB receiver is faulty.
Jul 09, 2009 | Logitech V450 Nano Cordless Laser Mouse
Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
May 13, 2009 | Casio Parts Cash Register PC Desktop
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Usb logitech mouse
Replace the 2 AA batteries in the mouse and then Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
May 19, 2008 | Dell PS2 keyboard 04N454
Cordless Desktop EX 90 Mouse Not Working
have you checked that it is the USB port if it is not in the USB port it will not respond
Feb 22, 2008 | Computers & Internet
Cant get Pointer to move
First try
Then if that doesn't work try
Feb 19, 2008 | Dynex Wireless Optical Mouse DX-WOM100
Logitech 9313960403 Mouse Logo
24 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
