Question about Panasonic PT-LB10VU Multimedia Projector
Optoma h27 colour issues
My projector at start up all colours are correct and true though after about five minutes the colours all changes. red is blue, blue is green, green is red
oh and lots of purple and pink people
the only true colour is black and white
the projector has a new globe what could the issue be
  • 4,234 Answers
Check to be sure that the projector is in the correct mode. If it is expecting an RGB signal and you send it (Y,Pr,Pb), you will see the picture as you describe. The same works for the above reversed. In all likelyhood, you are sending RGB and the projector is expecting the other.
Posted on May 07, 2008
After 10 minutes the colour wheel get out of synch and then a few minutes after that there is a crazy squeek and the lamp red indicator turns red light and the unit shuts off. I have opened up the unit...
Clean the Color wheel sensor thoroughly. a lens cleaning solution might help. be careful.
If problem persists.
Intall a 1" fan throwing air into the vent near height riser stud. into the color wheel chamber. this works.
Jun 13, 2011 | Optoma HD70 DLP Projector
I hv Sanyo PLC-SU07N Projector - the image is blue
I have a possible solution however it may not be THE solution your after, you'll probably be able to tell very quickly if it isn't, this will only apply if you are using either a component video signal or a PC/laptop signal to send to the projector.
If you are using a laptop or desktop to hook up your projector, I would try first of all double checking that it's correctly plugged in, and if you still have no luck try a different cable.
It's likely to be the cable because when the signal goes down the cable it's split into 5 different signals. 3 of these are the colour information for Red, Green and Blue. Depending on what you mean by 'image is blue', it could mean that your either not getting the information for Red, or your not getting the information for Red AND Green. If you want to test this, open up microsoft paint while connected to the projector and create 3 boxes, then fill 1 completely red, 1 completely green and one completely blue. If you are missing the information to any of these colours then that colour will appear black on the projector screen.
In component video the signal is split down 3 cables (rather than 5) and 2 are colours (rather than 3)... Red and Blue. Check that the cable running red (Usually labelled Pr on the DVD and projector) is completely plugged in (some of these are really tight, but it's important that it goes all the way) and also that you have plugged into the correct slot, for instance that you have plugged into Pr and not the right Audio channel, both of which are coloured red.
If you are still not having any luck then I would suggest using a computer monitor or a television (depending on what type of signal your sending it) to test the projector. Plug it in instead of the projector and if it works then the issue lies with the projector and I have at least narrowed it down for you.
Hope this has been helpful.
Mar 28, 2011 | Sanyo PLC SU07N LCD Projector
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
My pb6200 benq projector's colour is wrong. Missing green. Has a lot of blue & red. How do I fix this please? Have since replaced the lamp - does the same with both old & new lamp. Also has a...
Your correct about missing your primary color. this could be either your cable or the connection at the projector could have a bent pin on the port. not sure what your trying to display computer?
Jun 01, 2010 | BenQ PB6200 Multimedia Projector
Colour is very lacking in contrast
This could possibly be the colour wheel or the texas instruments dlp chip.
Apr 17, 2010 | Optoma HD65 DLP Projector
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
How do you approximate true colour with this unit?
first reset the settings to factory default. if that doesn't work, check the colorwheel. remove the lamp. in the little window inside the lamp housing, you'll see colored glass. that should spin. if there is no glass, it's not clear, or it does not spin, you'll have to replace it.
Nov 22, 2009 | InFocus LP70+ Multimedia Projector
Open Questions:
Panasonic PT-LB10VU Multimedia Projector Logo
288 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
