Question about Performance Teknique ICBM-5912 Car Subwoofer
How much does the performance teknique speakers usally go for? I have the 12inch 2000 watt
3 Suggested Answers
etirbynnor
  • 655 Answers
SOURCE: Kenwood 138 and Performance Teknique 752 speaker problem
Hello passionatete,
It sure sounds like the speakers are bad. When I looked these up, the specifications said they are 5 1/4 inch. You should listen to a few different speakers in the size that you require, to see what ones you like best. I'd first make sure of the exact size. Many 5 1/4" speakers have tabs that allow them to be mounted in 6 1/2" openings. The best way to determine which speakers fit is to use the "outfit my car" feature at www.crutchfield.com. They have speakers starting at around $35 per pair. Another good online site for research and for purchase is www.sonicelectronix.com. Sonicelectronix sells speakers starting as low as about $20 per pair.
Kenwood, JVC, Sony, Blaupunkt, and Orion are all excellent speakers for under $30. There's others like Boss, Scosche, Power Acoustik, and Visonik that cost even less. Again, I'd listen first, and then buy.
Hope this helps.
Posted on May 17, 2009
Zealot21
  • 83 Answers
SOURCE: I have 2 kicker cvr
Are your subwoofers wired in series or parallel? Check your connections, if everything is ok, the problem is with your amplifier. It might have a blown capacitor inside or its not really a 1ohm stable amplifier. Have it repaired if thats the case.
Posted on Apr 11, 2011
Need owners manual for 2000 digital amp
Try Googling (Performance Teknique)(2000)(manual) without parens.
Sep 22, 2017 | Performance Teknique Car Audio & Video
Whats the RMS Watts on a Performance Teknique ICBM 5910 I know it has 1500w peak but I'd like to know the rms watts on the subwoofer
Personally, I would not put more than 500 RMS total to that sub. 300-400 RMS is more like it.
Jan 05, 2014 | Car Audio & Video
I have 2 kicker cvr 15 4ohm dvcs and a performance teknique ICBM power 4000 watt 1ohm stable amp when I hook up my speakers 1 ohm it kicks my amp into protect when I wire it at 4 ohms it works fine how do...
Apr 11, 2011 | Performance Teknique Car Audio & Video
I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Need to if this sub is 2000 watts because i need to know what the ohms are
    You can find out the ohms with a digital multimeter. Just make sure it actually does ohms!
    Nov 02, 2010 | Performance Teknique ICBM-5912 Car...
    What wire goes where
    Hi they are dual voice coils so there is a positive and a negative for each coil its like two speakers in one.
    Feb 06, 2010 | Performance Teknique (ICBM-5742W) 12" 2000...
    What size amp should i get for performance teknique sub-woofers
    the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
    Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
    I Have 2 12inch jl audio subs and 1 800 watt kenwood amp and its just not enough boom, so was thinking about installing another amp (performance teknique ) but not sure how to wire it all up......n e help...
    How is it wired now? One amp with individual wire to the two subs in stereo mode? What are your plans? Are you adding a matching amp or just buying a larger one to replace the one you have?
    Jul 12, 2009 | Sony XM-SD61X Car Audio Amplifier
    2 1000watt 12inch
    tolally bad wiring on you spk if you say series parell chek the way the spk is wired in the box it could be wrong
    Apr 26, 2009 | Performance Teknique ICBM-892 Car Audio...
    Performance Teknique ICBM-5912 Car Subwoofer Logo
    49 people viewed this question
    Top Performance Teknique Car Audio & Video Experts
    hoyzee1
    Jose Velazquez
    Jose Velazquez
    George Nalley
    Level 1 Expert
    Are you a Performance Teknique Car Audio and Video Expert? Answer questions, earn points and help others
