Question about Minolta DiALTA Di520 Laser Printer
Minolta dialta di250
When i power copier on the following message appears; malfunction detected call rep c-0048. ibroke the bottom door switch that opens bottom compartment but i dont think that is what malfunction is. tried calling svc # but they are in another state and said they thougt message had to do with a fan needing to be cleaned.found your site while looking for a dealer/svc ctr nearby. would appreciate any help you could provide . thank you, joe serial no is 6113598 and ID A0987
  • Minolta Master
  • 1,294 Answers
The C0048 error code not exist.Malfunction resetting procedure:
Turn OFF,then ON the power switch or open and close the side cover for all malfunctions except C05XX codes.
Use Trouble reset of the Initial screen to reset all malfunctions.
To right side the touch panel(screen display)near display contrast button exist a little hole (reset switch).Insert a hairpin to touch the switch.
Enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screen being displayed.Touch TROUBLE RESET,and EXIT to go back to the basic screen.
Posted on Jul 31, 2009
Cob08 error
If your copier is Dialta 250 reset the malfunction code.
Push the warm restart switch located on the right side to control panel in area of display contrast knob(hole) and enter "3" from the 10-key pad when " * " appears at the center on the left side of the screen while the start up screenis being displayed.Select the trouble reset and touch exit.
Feb 11, 2013 | Minolta DiALTA Di250 All-In-One Laser...
We need the chapter 14 of the manual for minolta dialta di250
Have you tried the Konica/Minolta website? They may have the manual in PDF format that will give you the needed chapter. Good luck.
Aug 04, 2009 | Minolta DiALTA Di250 All-In-One Laser...
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12c0 in minolta di 550
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Error c12co in minolta di550
Minolta dialta di520
problem code c1039  for d-i 620
May 10, 2008 | Minolta DiALTA Di520 Laser Printer
Minolta Di250 copier
That malfunction is a toner motor drive problem. It has most likely died, or the motor has jammed. Check for any sort of jam inside the printer near the toner motor. Otherwise, you will need it professionally repaired. There is no quick and cheap fix for this problem, unfortunately.
Sep 06, 2007 | Minolta DiALTA Di250 All-In-One Laser...
207 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
