Question about Olympus SP-550 UZ Digital Camera
Camera fairly new and will not work. Message reads lens error!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 29, 2010
System error Zoom
Lens errors (system error zoom on Panasonics) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Apr 13, 2012 | Panasonic Lumix DMC-FH27 / DMC-FS37...
Lens barrel is stuck in the out position on my Canon Powershot SD1100 IS. Error message reads: "Lens error, restart camera". To my knowledge the camera has not been dropped and the barrel seems...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 20, 2011 | Canon PowerShot SD1100 IS Digital Camera
My camera battery died while I was shooting and the lens was out_ new batteries but now I am getting a lens error message!_ the lens will not retract! help!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 02, 2010 | Canon PowerShot A470 Digital Camera
The lens does not retract
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 06, 2009 | Canon PowerShot A560 Digital Camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 14, 2009 | Canon Cameras
Camera felled to floor lens tries but cannot retract camera turns on and off fine, error message "lens error, restart camera" it appears that until lens can function properly and error message is resolved...
Jun 29, 2009 | Canon PowerShot A630 Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Problem with the lens
Apr 25, 2009 | Cameras
"LENS ERROR, RESTART CAMERA", THIS IS NOT WORKING.
Feb 20, 2009 | Canon PowerShot A540 Digital Camera
E 18 Message
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Olympus SP-550 UZ Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
