Question about Nikon Speedlight SB-800 TTL Flash
My sb will power on but i have no flash even when i hit the test button. I noticed it got a little warm then shut down when the problem first occured. Is it fried or fixable?
    Champion:
  • Nikon Expert
  • 225 Answers
Are you using fresh batteries? Are they rechargeable batteries if so do a battery test maybe a battery is weak. With fresh batteries it still does the same thing then call Nikon 1-800-645-6689
Posted on Aug 30, 2010
SB-800 Stuck in REMOTE
http://www.nikonusa.com/fileuploads/pdfs/SB800_sellsheet_060425.pdf
hers the manual on cam look under trouble shooting im still cheaking into it also
Feb 08, 2008 | Nikon Speedlight SB-800 TTL Flash
Trimble juno sb won't turn on
I have the same problem with my Trimble Juno SB. It just happened today. But when I plug mine in to a power source the LED is green. But when I hit the power button it flashes red one time. I have tried soft and hard resetting it. And I even tried the 'restore factory settings' reset. Nothing works, It just stays off. The screen never comes on.
Did no one else read the question? It isn't for a laptop. It is for a Trimble Juno SB.
Jul 17, 2013 | Computers & Internet
Stuck in AF-ILL ONLY mode
Is the flash still on the camera when you do this? If so, check your camera settings as well as the camera may be over-riding you.
If the flash is not on the camera, some of the settings for custom settings can only be changed with it on the camera via camera commands.
If you do not have the manuals, you can get them here:
http://www.nikonusa.com/pdf/manuals/Speedlights/SB-800.pdf
http://www.nikonusa.com/pdf/SB800_techniques.pdf
Feb 19, 2012 | Nikon Speedlight SB-800 TTL Flash
HP DV928US When battery in or charger plugged in
fails battery out so leave it out they love to short.
so when it fails test 2 is, hit the F10 or ESC key promptee
went it fails to boot, check BIOS key first, if BIOS fails.
be more clear.
what does it do when it wont turn on.
BIOS dead. screen 100% dead, and not even text
BIOS works even with HDD and DVD drive pulled.
that is the acid test on PCs.
the screen must say, hit F10? or ESC to enter setup, means HP BIOS. it must or power is no good. get a new power pack
the shut down tell me lost power, that can be the power pack 19vdc
or the jack at the mobo if failing to said pack.
try side pressure on that jack if at anytime the power button fails.
it self shuts down, I got that but lets fix , cant boot first.
that is how to fix this.
power on failures, are you saying the power key fails. some times
and the fan does not run every time.?
Also,
this old LT uses CCFL back lamps.
that love to fail. so when it shut down did the fan die.
did the HDD stop spinning ear to bottom? if not the CCFL is failing.
using and external monitor proves this every time,
do the flash light trick?
http://www.pcdied.com/monitors.html#flashlighttest
Aug 29, 2017 | HP Pavilion dv6928us Notebook
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Blue led power light blinks even after shutdown
What operating system are you using? When the power led continues to slowly blink, that means that the laptop is in standby mode and not fully shut down. In Vista, if you hit the power button on the laptop or the power button under the start button, it is configured to go to standby and not shut down. Make sure to hit the arrow all the way to the right and select shutdown from the list of dropdown options.
Aug 28, 2009 | Gateway Computers & Internet
Acer 5570 southbridge overheats and shutsdown
well,if you r able to get to bios then check power managment sction and reduce CPU speed and try to deactivate one of the peripherals that is responsible of thi shorting out= over warming.
as long as the southbridge chip over warms every time you turn on you laptop thats mean the S.B is facing a shorting out on it IC.
you can clean underneath/surround it.
plz rate.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
Mar 06, 2009 | Nikon Speedlight SB-600 TTL Flash
Using a speedlight sb800 off camera on a Nikon d80
Found a great website that explains this since it's not in any of the manuals or other websites I have searched for so long!
http://www.kenrockwell.com/nikon/ittlslave.htm
HOW TO DO IT
This covers the D70 and SB-600 which I use personally. It should be similar on other cameras. Any questions? Presuming you have USA equipment, call (800) NIKON-UX for details.
On your D300:
Press MENU.
Move up or down to: PENCIL menu.
Move right and down to: e Bracketing/Flash
Move right and down to: e3: Flash cntrl for Built-in Flash
Move right and down to: C Commander Mode
On your D70:
Use P, S, A or M exposure mode.
Press MENU. Go to the yellow wrench menu, and be sure CSM MENU is set to DETAILED. Otherwise you won't see the next setting!
Go to the CSM menu which looks like a purple pencil. Set #19, Flash Mode, to "COMMANDER MODE." Further click to the right to set the commander mode to "TTL."
You also may set the commander mode to Manual or AA, which are other modes to fire the remote flash. The SB-600 only works with TTL and Manual. You set the manual power level at the camera.
Don't forget to POP UP THE BUILT-IN FLASH!
On your D200:
Press MENU.
Move right and down to: e3: Built-in Flash
Move right to get to a confusing panel of C Commander Mode settings.
Once in this confusing panel you can set everything for two external groups of flashes and the built-in flash. You move between the different fields by moving left and right, and set any field by toggling up and down.
In this panel you must select Channel, and set it to 3. Default is 1, which is the default for the SB-800. Don't ask me why they are different. Default for the SB-600 flash is channel 3, so if you forget this it won't work! Sorry about the complexity; Nikon didn't ask me for help here.
This is such a pain I use one of the D200's setting banks to store this.
On your SB-600:
Hold down ZOOM and "-" together to enter the CSM settings. That's why you see a gray "CSM" marking between those two buttons.
Press either the + or - buttons until you see an icon that looks like a wiggly Z-shaped arrow. This arrow refers to wireless communication between the flash and camera. When you see the wiggly arrow, press MODE to make it say ON.
Press ZOOM and "-" together to get out of the CSM mode. Even easier, just tap the power button to get back to normal operation. It won't turn off if you hit it while in the CSM settings.
Presuming you did this correctly you'll see "CHannel 3" and "GROUP A" displayed. If you see different channels or groups then press MODE to get one or the other to flash and then the + or - buttons to set them back to 3 and A. No, I have no idea why these are the settings you have to use instead of 1 and A; 3 and A are what you need to talk to the D70's built in flash. If you get smart and choose others then it won't work. The other channels and groups are for people much smarter than I who want to try to rig up a zillion flashes to work together and control them all separately and remotely. I prefer professional studio strobes if I'm using more than one strobe at a time.
The SB-600 doesn't go into standby in this mode, so you can run down your batteries if you forget and leave it this way. It just sits there blinking its little red LEDs visible from the front.
HOW TO SHOOT
Easy, just shoot! If you set everything to TTL as I suggest then the camera just does everything. You and I are free to concentrate on the more important parts of making a great image.
Everything is controlled from your camera. This is very convenient if you have the strobes someplace remote, like duct taped behind plants.
You can control the remote flash's output simply by varying the flash exposure compensation control on the camera. You can do that without taking your eye away from the finder! You do that by pressing the same button you used to pop up the flash and then moving the front control wheel. You'll see the amount of compensation on both the camera's top LCD as well as through the finder. Brilliant! You can add more or less flash fill without having to walk over to the remote flash.
You can set the mode (TTL, Manual or AA) from the camera.
You can set the manual power level from the camera as well.
Try to have the little black window on the bottom right of the flash (marked with that same wiggly arrow) pointing in the general direction of the camera. Thankfully it's not a big deal; you don't even need a line of sight so long as the flash is anywhere near the camera or subject.
The sensor is sensitive enough to pick up the flash from the camera even if it has to bounce around a corner or off the subject. This makes this current system so much better than the older ones. You can hide flashes anyplace and even if they can't see the camera they usually go off correctly. They beep to let you know what's going on, even if you cant' see them.
The i-TTL system is much better than the old systems because it just works. If you ever used the older systems you'd know that half the time you'd get no flash, or a full-power flash that also wasted the shot. This new system just works, and that's critical for use in the field where the remote flash is rested on a garbage can or held in your left hand while you hold the camera with your right.
I even can have the flash in a different room out of view of the camera and it goes off just fine.
It works fine even 50 feet away. I haven't tried it any further. Honestly I have no need for a flash that far away; I was just seeing if it worked.
Jul 01, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon Speedlight SB-800 TTL Flash Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
