Question about Ovens
If you have Model# KERC507, YKERC507, or YKERS507 made in 2001 what would you recommend in this years models?
Replaced control panel and keypad 1 1/2 years ago seen the error codes now I was self cleaning oven everything went off no error codes or anything house breaker ok PLEASE help.
Self clean is hard on controls. I do not recommend self clean. Kills expensive parts. If the temp goes above 300 in the control panel, a control panel fuse will melt, killing the power to the control.
It looks like this:
Service manual for late model whirlpool double oven
and some more interesting oven stuff
Mar 08, 2011 | Whirlpool GBD307PDS Electric Double Oven
Kenmore electric range model 790.94359700 oven element does not work (heat up)
It appears your heating element/coil has failed in this instance.
First - unplug the unit for 40 minutes and re-try.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have an older Brown gas Range (Frolic) 20" Model F100 and I need a thermocouple for the oven burner control valve. How& where can I get one
Sep 23, 2010 | Brown Stove Works TTM721-DK Gas Single...
The clock continue to run when the oven is on. When the oven off. The clock continue to run. The alarm goes. The oven is a Tappan. I will have to get the model later. I t has led panel just for clock and...
It appears your clock has failed in this instance.
Sep 17, 2010 | Ovens
Kenmore gas range model 362.7361891 - wrong temp.
It appears your thermostat/probe has failed in this instance.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
HAVE A E1 F2 MESSAGE. WHAT DOES THAT MEAN?
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Sep 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Messed around with the timer on my kenmore electric oven (with self cleaning option) now it wont heat up? note: this is an older model oven with the old clocks!
It appears your ERC/CLOCK has failed in this instance.
May 14, 2009 | Kenmore 30169 Electric Single Oven
Kenmore oven Model 911.30169792 Control panel lights are on
Apr 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Older Kenmore single oven/microwave ovens model # 49425 or 49429. All at once oven started beeping and flashing "fault F8" and don't know what to do. Can you advise?
Feb 25, 2009 | Kenmore 47792 / 47794 / 47799 Electric...
Kenmore 911.47649100 Double oven
Dec 23, 2007 | Kenmore 49069 Electric Double Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
