Question about Toshiba Qosmio G25-AV513 Notebook
Just bought new qosmio , and simply wont turn on. Is there any trick or just need to use waranty. Is problem in adapter maybee? Regards, Kristian kraljic
  • Toshiba Master
  • 4,737 Answers
If it's still under warranty, you are lucky, but you can still try if it's a small faulty. First disconnect the charger and Switch On with the battery installed. It it doesn't work, remove the battery and try power on with the Charger connected. Still nothing, then check whether it is charging or not (battery installed and charger connected), you'll see a light if it's charging. If nothing seems working, then you last option is the Warranty.
(do not open the case or any cover, it may void the warranty).
Good luck.
Thanks for using FixYa.
Posted on Aug 28, 2010
How can I find the driver to the DVD-player on a Acer ASPIRE M5800 with a dual-layer DVD burner ?
You shouldn't need a driver it's just generic DVD optical drive. Are you able to read any discs? Is the issue with burning or watching DVD videos?
Jul 29, 2014 | Acer Computers & Internet
Wont recognize the hard drive on my toshiba qosmio g55-q804
If this is a new drive, it needs to be initialized first. If not, then it may be faulty.
Nov 02, 2013 | Toshiba Qosmio G55-Q804 PC Notebook
How do i install 3D for Toshiba Qosmio X775
The 3D capability should be ready to go if you bought it new. Put on the special 3D glasses that came with it, and press the soft-touch button labeled "3D" near the LCD screen between the speakers... Don't forget to but the batteries in the glasses (or charge them if permanent), and turn them on...
Sep 15, 2012 | Toshiba Qosmio X7753DV78 173Inch 3D Gaming...
How to install windows xp in toshiba qosmio f30-112
If the Notebook cannot find the device driver it is looking for then use this restore disk for an easy solution.
WINDOWS IS NOT ON THIS RESTORE DISK
This restore disk will only work for use with Toshiba Qosmio F30-112. This restore disk contains every driver for the Toshiba Qosmio F30-112.
http://restore-disk.com/shop/CartAdd.asp?ID=149816
Toshiba Qosmio F30-112 XP ... windows XP restore disk is a one stop solution. The Qosmio F30-112 drivers in ... Toshiba Qosmio F30-112 XP Notebook plug and play will install ...
TOTAL: $15.92
hope this helps
Sep 12, 2012 | Toshiba Qosmio F30-112 Laptop DC Car...
My Toshiba Qosmio X305-Q705 Laptop Power AC Adapter is not receiving any power.
A similar thread about laptop not receiving power from ac adapter below, may it would help:
http://forums.bit-tech.net/showthread.php?t=107029
Feb 17, 2011 | Lifetime Toshiba Qosmio X305Q705...
My laptop Toshiba Qosmio F45- AV413 doesn't turn on. When I press the power button looks that will turn on, but shut down right after. All the lights looks fine, when I plug the power cable the light turn...
Take the battery out & see if it works then, perhaps the battery is so flat it is holding down the PC. It will should go on just the adapter. If this works, then you will have to plug battery back in, & adapter and leave alone for at least 8 hours. If it still won't work, you may need a new battery.
Mar 11, 2010 | Toshiba Qosmio F45-AV412 Notebook
I JUST BOUGHT MY ACER NETBOOK TWO WEEKS AGO AMD NOW IT WONT BOOK BECAUSE IT SAYS MEDIA TEST FAILURE NO OPERATING SYSTEM PLEASE HELP
you ll have to reinstall windows using a external cd drive plugged into a usb port and set it up in bios to boot external drive 1st also ur hd may be faulty but unlikly being so new unless u have slammed it down/dropped it or have caused it to overheat or simply being playing about in bios and turned it off maybee
Oct 02, 2009 | Acer Aspire One PC Notebook
The power adapter on the back of my qosmio g35 is loose i.e. it wiggles back and forth. in order to get the power supply to work i have to "anchor" the power adapter to one side or the other else i get no...
If the pin inside the adapter is loose then at some point you are going to have take the laptop in for repair as it will shortly fail and snap.
Unfortunately you can't tighten them up but you can have a new adapter soldered onto the motherboard.
If you take the laptop to a reputable repair store they will no doubt do the job for you, don't however let them fob you off by saying that you will need a new motherboard as these day's it's not the case.
Regards.
Aug 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Wont turn on
Replace your AC adapter.
Jun 29, 2009 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
