Question about Kodak EasyShare M1033 Digital Camera
When I turn on the camera it chimes than shuts off the lens is in the open position and will not power up to close it
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 28, 2010
When turning on camera the lens will open then shut off on a fully charged battery. It will allow you to view pictures on the camera by selecting the favorites and turning it on but when you turn the...
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Your batt. is covered under the same man. warranty as your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 05, 2009 | Kodak EasyShare M863 Digital Camera
Lense opens and closes and then shuts off
It appears that the camera lens is off track.
Since the camera is not working right you can try these things.
First, just to tell you, that by doing the following you could damage the camera further, so take it at your own risk.
What I have done in more than a few times is to examine and watch closely to what happens to the lens as it goes through it's process of in and out. This usually indicates that the camera processor is trying to get the lens to adjust to it's correct place. This is most time the result of an impact of some sort.
What can be done?
As you turn on the camera carefully hold the lens back with something flat or simply hold on the sides of the lens to cause it to reset to a new position. Turn the camera off.
Try to turn on the camera and see what happens and if there is any change. This will determine if you need to try again and go through the same process.
By continuing the above, it may be possible to get the lens back on track.
To tell you... most lenses are made very similar for digital cameras. The extension tubes of the lens is attached to some kind of small tracking devices. This varies, but all will track in a small groove to the fully extended position.
What we are trying to do is to reset the gear position to where the camera processor will know by the sensors that the lens is in the correct position. Also to remember that there are very small gears which can break with too much pressure, but also can "jump a notch or two" to reset it to the correct position. Speaking of that... if there is a grinding or jumping sound (when starting with out any back force)...like stripping or sounds of broken gears..then trying to reset the lens will not work. In which case if may be better to sell the camera for as is or parts on a site such as Ebay.
Aug 30, 2009 | Olympus FE-230 Digital Camera
When turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
KODAK Z1275
I semi resolved the problem with my Kodak Z1275 with this suggestion; Step 1, making SURE the batteries are good. Then, position the camera with the lens pointed up or down (depending on stuck lens position, USE GRAVITY AS YOUR FRIEND) and gently tap on the lens just as you turn on/off the camera. You may have to do this several times before the camera will close the lens. From my research this camera has a faulty mechanism for the lens which causes the software to recognize a lens failure thus shutting down the camera. Poor designed lens mechanism! I now am using my camera again, but regularly have to remember to allow gravity to assist in lens opening (turning on) and lens closing (turning off) as well as occasionally giving it a light tap or in extreme cases lightly assisting the lens opening/closing. Hope that helps! Oh and I don't suggest buying another Kodak camera!
Sep 15, 2008 | Kodak EasyShare Z1275 Digital Camera
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
Jul 24, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens won't retract : /
Another common problem. Lens troubles. You have either knocked your lens out of alignment or you have a foreign body jamming up the works in the lens control unit. There have been many so called fixes for these problems but usually end up causing more problems than curing. You could check that you have fully charged new batteries. Some cameras need that extra kick to get them to open the lens fully. Worn out batteries can stop a sticky lens in it's tracks and tell the processor there is a problem and to close down. It's well worth trying before writing it off.
Jul 06, 2006 | Panasonic Lumix DMC-FX8 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Kodak EasyShare M1033 Digital Camera Logo
69 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
