hi all, i have the above mentioned card and since i have installed windows XP service pack 3, i cant use the D-link utility that came with.
is this a driver issue or is the utility not compatible with SP3?
Comment by chowzen, posted on May 08, 2008
it works this way.
3 Other Users Have The Same Problem
Comment by rbentley, posted on Aug 10, 2008
I had the device working fine on SP2 but then I installed SP3 and had the wlanapi.dll problems. So I downloaded and installed the new drivers from the D-Link website, but now when I plug in the device I get the message "Wireless networks detected......to see the list and connect click this message" and when I click it and get the Choose a Wireless network dialogue box it says that "No wireless networks were found in range". I have uninstalled, installed, and tried everything I can think of but still get the same result. The device is ok as it works on another computer (but running on SP2). Any suggestions - I am desperate!
Richard
Comment by tovt, posted on Jul 07, 2008
The same problem. Just installed SP3. AirGCFG.exe (e.g., when D-Link AirPlus Utility is trying to start) reports "Enter point to aspGetInterfaceCount is not found in wlanapi.dll".
Can't find any solution at D-Link site.
Comment by pasqualpp, posted on May 10, 2008
the problem I have is same. At start the airgcfg.exe and wzcsldr2.exe can not start as the process apsgetinterface and apsinitialize are respectively not found in the dynamic library wlanapi.dll
Rating: 0%, 0 votes
http://support.dlink.com/faq/view.asp?prod_id=3002
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
to wlanapi.dll.sp3 -- as an example. Then copy the pre-SP3 wlanapi.dll, as found in the uninstall-folder, to folder %windir% \ system32, reboot, you're done. As far as I had to check out a couple of wlan-related items in such a short time, I couldn't see any inconvenience right now. Try it out for yourself. cheers, Frank.
PS: If you don't have a clue what I am talking about, you should refrain from doing so.
Post a New problem for D-Link AirPlus DWL-G630 802.11g/b
Email this problem
Can you Help with these Wireless Adapters problems?
how to set up brother mfc-465cn...
VMCLite: No n/w activity after...
D-Link AirPlus DWL-G630 -...
